Difference between python toolbox and python external ?
1384
02-27-2012 10:57 AM
OlivierOlivier
I try to list all layers from an mxd. Can someone explain me why it works when launched from toolbox and not from an Idle python script ?
mxd = arcpy.mapping.MapDocument(r"...\my.mxd") for df in arcpy.mapping.ListDataFrames(mxd,"*"):     for lyr in arcpy.mapping.ListLayers(mxd,"*",df):         print df.name + ":" + lyr.name
When launched with a tool inside Arcmap 10.0, I get all layers, but from python 2.6 script, it just displays the first layer and stops (Layers:<first layer name>).
Thanks for any help
Olivier
MathewCoyle
Honored Contributor
It worked fine for me from IDLE. Have you tried it using different mxds?
MathewCoyle
Honored Contributor
OlivierOlivier
Thanks Matthew, your answer helped me to investigate, it worked with other mxd.
So I did a reboot and finally it's ok. A bit strange but as I did many Python tests on this machine and this mxd during the previous day, perhaps something gone wrong.
Olivier
