Descripencies between Attribute Table (arcmap) datetime and the value read by arcpy.
1538
10-25-2012 08:20 AM
KevinMorris
I have recently observed descripencies in time between what is shown in the attribute table in arcmap and what is obtained from reading the date field in python. In particular approximately 1 out of 10 time elements differ by one second. This difference prevents use of the datetime field for identification of duplicates.
Flow: JSON serialized datetime (1) -> python datetime obj (2) -> written to feature class as obj (3) -> read from feature class (type = date) as obj(4).
In the process the time element is consistent from step 1 to 3, however, the read time in (4) may be one second less than observed in the attribute table.
Code to match and/or convert JSON to ESRI 10.0(python) datetime (and others):
def MatchDataType(ESRI_Cursor_Object, JSON_Data_Structure):
    DType = ESRI_Cursor_Object.type
    DName = ESRI_Cursor_Object.name
    JData = JSON_Data_Structure[DName]
    if DType == 'SmallInteger':
        return int(JData)
    if DType == 'Integer':
        return int(JData)
    if DType == 'SHORT':
        return int(JData)
    if DType == 'LONG':
        if long(Jdata) < 2147483647:  # Had to add this due to GeoPro 16 digit Integer range greater than ESRI accomodates with LONG
            return long(JData)
        else:
            msgr('Conversion to long above ESRI limit for long integer')
            return
    if DType == 'Single':
        return int(JData)
    if DType == 'Double':
        return long(JData)
    if DType == 'String':
        return str(JData)
    if DType == 'Date':
        if JData.find('Date('):     # Java JSON date is expressed as milliseconds since IBM inception Date(XXXXXXXXXXXXX-YYYY) X = milliseconds Y=offset (positive or negative?)
                                    # eg. /Date(1348860772000-0400)\  Note that if you do a find on '/Date(' it can fail! Some of my tests were successful others not.
            try:                    # poor man's error checker in case the date stamp is not correct. In this case return nothing
                index = int(JData.find('Date('))
                JData_milliseconds = int(JData[index + 5:index + 5 + 13])       # rip out the milliseconds in the proper placement starting from the location of finding the match
                JData_hourshift = int(JData[index + 5 + 13:index + 5 + 13 + 5])
                dt = datetime.datetime.fromtimestamp(round(JData_milliseconds/1000))  # need to get rid of the tailing bits of real info due to conversion to ESRI date that round this information differently.
                dtn = dt - datetime.timedelta(hours=round(JData_hourshift/100))        # not sure if I should be subtracting/adding this hour shift or what exactly this means. Only want the hour not minutes.
                return dtn                                                     # may need to only convert the -04 to integer, need to verify dates against the GeoPro webpage.
            except:
                return
    return
The code writing the datetime element uses a regular insert cursor and converts the JSON data (Gmsg) as a python dictionary list into a matching field in the feature class based upon the feature class field type (predefined).
# Create the ESRI point geometry
                            inPoint = arcpy.Point(SEKI_Location['Longitude'],SEKI_Location['Latitude'])
                            newIncident = rowInserter.newRow()
                            # Populate Shape Attributes
                            newIncident.SHAPE = inPoint
                            # Populate matching fields.
                            for field in fieldList:         # loop through the Feature class attribute names
                                if field.name in Gmsg.keys():
                                    print field.name
                                    newIncident.setValue(field.name, MatchDataType(field, Gmsg))
                            # add attribute stuff here
                            rowInserter.insertRow(newIncident)
                            # newIncident.setValue(descriptionField, inDescription)
It can then be read lader and matched, however the times may be off by one second.
This is observed as a discripency in the print statement. Approximately one out of 10 times will be off by one second
def IsDuplicateEntry(GeoPro_fc, ComparisonList,FieldList, GeoProMessageObject):
    # SCursor=SearchCursor.reset()      unsupported                                        # reset the search cursor in the feature class for checking the next entry
    Duplicates = 0
    SCursor = arcpy.SearchCursor(GeoPro_fc)
    try:
        for row in SCursor:                                                      # Iterate through all the rows to find a match if there is one
            Duplicates = 0
            for ComparisonName in ComparisonList:
                if ComparisonName == "EventDate":
                    print row.getValue(ComparisonName), ' --- ', MatchDataType(GetESRIFieldObject(ComparisonName, FieldList), GeoProMessageObject)
                if not(row.getValue(ComparisonName) == MatchDataType(GetESRIFieldObject(ComparisonName, FieldList), GeoProMessageObject)):
                    continue                                                    # if there is any non match we don't need to keep checking
                else:
                    Duplicates = Duplicates + 1
            if Duplicates == len(ComparisonList):                                # if all the comparison fields have duplicates then this is a duplicate record and pass a True message
                #del row
                #del SCursor
                return True                                                     # This record is a duplicate - no need to keep searching through the feature class.
        #del row
        #del Scursor
        return False
    except:
        #del row
        #del SCursor
        return                                                            # If there is an unusual error just pass the duplicate found flag.
JasonScheirer
Esri Alum
Could you provide a (greatly) simplified version of your code here without all those extra library calls? You're using a lot of functions and have not provided any context, so I don't know if I can make any assessment of what's going on that can be accurate.
JasonScheirer
Esri Alum
You may also want to be aware that internally Dates are stored as double precision floats, which are notoriously flaky once you get into large degrees of precision.
KevinMorris
I didn't realize the time/date field was of floating point. I'll try some modifications to prevent possible "leakage" and also see if timedelta.resolution will help with similar dates with minor fp mathematic differences.
KevinMorris
Because of a number of issues I have converted all code to SQL Server 2012 and use a query layer on a geographic table.  Response is excellent and it is easy to code. MapTips does not appear to work, however, even with a spatial index set in SQL and redetermined in ArcGIS 10.1
Issues:
(1) date/time ambiguity
(2) inability to reset the cursor in a feature class (in the documentation but does not work). This requires reopening a feature class multiple times.
(3) no support in arcgis for enterprise size fields such as an 18 digit number (originally converted to char).
Cheers
Kevin
