density calculation using cursors in arcpy module
2971
07-14-2016 06:04 PM
GregAranea
DanPatterson_Retired
I would first suggest doing it manually, then copy to a python snippet... see details here
Using the Results window—Help | ArcGIS for Desktop
GregAranea
thank you
WesMiller
You may be working harder than you need to:
Use Spatial Join—Help | ArcGIS for Desktop  to get a count of your wells in each county
And then use it again(the other way around) to create a table with wells and county names, then you can Add Join—Help | ArcGIS for Desktop  to your wells then use Calculate Field—Help | ArcGIS for Desktop to populate your field with county.
