Date field attribute not displaying correctly
2917
11
04-25-2014 03:01 AM
H_A_D_Padmasiri
Dear Sir
I entered date field as variable like VDate = Sys.argv[4] using arcpy.CalculateField_management("BLD_PG", "BLD_PG_DT", VDate, "PYTHON_9.3", "")
But in attribute table  attribute of the Date field look like 12:01:00 AM. How to correct it?
Thanks
Padmasiri
JakeSkinner
Esri Esteemed Contributor
Hi Padmisiri,
You will want to format the date like the following:
time.strftime('05/02/2014')
Ex:
arcpy.CalculateField_management("BLD_PG", "BLD_PG_DT", "time.strftime('05/02/2014')", "PYTHON")
H_A_D_Padmasiri
Hi Padmisiri,
Ex:
Can you please explain How to enter '05/02/2014' as a variable. (VDate)
Thanks
JakeSkinner
Here is an example:
VDate = "time.strftime('05/02/2014')"
H_A_D_Padmasiri
Here is an example:
Thank you for your answer.it runs correctly, But I add a field called "BLD_PG_DT"(Date Type) it gives me following error.
I cant understand the error. can you correct it.
Thanks
Padmasiri
VDate = sys.argv[4] # This date value from the calender
arcpy.AddField_management("BLD_PG", "BLD_PG_DT", "DATE", "", "", "", "Validity Date", "NULLABLE", "NON_REQUIRED", "")
arcpy.CalculateField_management("BLD_PG", "BLD_PG_DT", "time.strftime('VDate')", "PYTHON_9.3", "")
  File "J:\Gampaha\Scripts\Creating_Building.py", line 57, in <module>
  File "c:\program files\arcgis\desktop10.1\arcpy\arcpy\management.py", line 3128, in CalculateField
    raise e
ExecuteError: ERROR 999999: Error executing function.
The value type is incompatible with the field type. [BLD_PG_DT]
Failed to execute (CalculateField).
Failed to execute (LISTool1.02).
JakeSkinner
Can you post your entire code?  Be sure to wrap it in the appropriate
 tags.
H_A_D_Padmasiri
 tags.
Dear sir
My entire code is send here with. Pl see attachment.
Thanks
Padmasiri
JakeSkinner
For some reason, I could not get this to work with 'sys.argv' but I was able to with arcpy.GetParameterAsText.  Are you able to use the GetParameterAsText rather than sys.argv?
H_A_D_Padmasiri
Dear sir
When I save a date as a variyable, which I take from the calender like (mm/dd/yyyy).
My question is why that variyable directly enter to date field without formatting ?
What is the correct method to enter in to the date field which I take from the calender?
I cant understand what is the purpose of using calender.
Kindly explain me.
Thanks
Padmasiri
JakeSkinner
Hi Padmasiri,
Try replacing your sys.argv arguments with arcpy.GetParameterAsText.  Here is an example:
# Import arcpy module
import arcpy
import os
from arcpy import env
import shutil
import sys
import time
# Local variables:
Cad_File = arcpy.GetParameterAsText(1)#J:\Gampaha\510272\51027202.dwg
Pro_File = arcpy.GetParameterAsText(2)#I:\Projections\ProSriLanka99_5
Folder_Loca = arcpy.GetParameterAsText(3)#J:\Gampaha
VDate = "time.strftime('" + arcpy.GetParameterAsText(4) + "')"
Folder_Name = os.path.splitext(os.path.basename(Cad_File))[0]#51027202
Out_folder = os.path.join(Folder_Loca, Folder_Name)#J:\Gampaha\51027202
Gdb_Name = "CAD" + Folder_Name#CAD51027202
Gdb_Name1 = "CM" + Folder_Name#CM51027202
Gdb_Path = os.path.join(Out_folder, Gdb_Name)#J:\Gampaha\51027202\CAD51027202
Gdb_Path1 = os.path.join(Out_folder, Gdb_Name1)#J:\Gampaha\51027202\CM51027202
Fea_Dset_Name = "CAD" + Folder_Name#CAD51027202
Fea_Dset_Name1 = "CM" + Folder_Name#CAD51027202
Fea_Class_Path = os.path.join(Gdb_Path1 + ".gdb", Fea_Dset_Name1)#J:\Gampaha\51027202\CM51027202.gdb\CM51027202
if os.path.isdir(Out_folder):
    arcpy.env.workspace = Out_folder
    Gdb_List = arcpy.ListWorkspaces("", "FileGDB")
    for GDB in Gdb_List:
        arcpy.Delete_management(GDB)
    shutil.rmtree(Out_folder)
Ws_Path = Gdb_Path + ".gdb" + os.sep + Gdb_Name
arcpy.DefineProjection_management(Cad_File, Pro_File)
arcpy.CreateFolder_management(Folder_Loca, Folder_Name)#J:\Gampaha\510272\51027202
arcpy.CreateFileGDB_management(Out_folder, Gdb_Name, "CURRENT")#J:\Gampaha\51027202\CAD51027202.gdb
arcpy.CreateFileGDB_management(Out_folder, Gdb_Name1, "CURRENT")#J:\Gampaha\51027202\CM51027202.gdb
arcpy.CreateFeatureDataset_management(Gdb_Path1 + ".gdb", Fea_Dset_Name1, Pro_File)#J:\Gampaha\51027202\CM51027202.gdb\CAD51027202
env.workspace = Gdb_Path + os.sep + Fea_Dset_Name
#arcpy.env.Scratchworkspace = Gdb_Path
arcpy.CADToGeodatabase_conversion(Cad_File, Gdb_Path + ".gdb", Fea_Dset_Name, "2000")
arcpy.CreateTopology_management(Fea_Class_Path, "PCL_LN_Topology", 0.01)
Polyline = Ws_Path + os.sep + "Polyline"
Pnt = Ws_Path + os.sep + "Point"
PLN_Topology = Fea_Class_Path + os.sep + "PCL_LN_Topology"
Fea_Class = Fea_Class_Path + os.sep + "BLD_LN" #NL
#Creating Structure Feature Class
env.workspace = Fea_Class_Path #NL
arcpy.FeatureClassToFeatureClass_conversion(Polyline, Fea_Class_Path, "BLD_LN", " \"Layer\" = 'OBJ-MAN-MADE' ")
arcpy.FeatureToPolygon_management(Fea_Class, Fea_Class_Path + os.sep + "BLD_PG", 0.01, "ATTRIBUTES", "")
arcpy.AddField_management("BLD_PG", "BLD_PG_NM", "TEXT", "", "", "50", "Building Name", "NULLABLE", "NON_REQUIRED", "")
arcpy.AddField_management("BLD_PG", "BLD_PG_CD", "SHORT", "", "", "", "BLD SD Code", "NULLABLE", "NON_REQUIRED", "")
SubType_Dict = {"0": "Permanent Building", "1": "Temporary Building", "2": "Building Underconstruction"}
arcpy.SetSubtypeField_management("BLD_PG", "BLD_PG_CD")
for code in SubType_Dict:
        arcpy.AddSubtype_management("BLD_PG", code, SubType_Dict
arcpy.SetDefaultSubtype_management("BLD_PG", "0")
