da.UpdateCurso: Where clause for geometry
1100
02-06-2014 12:46 AM
Marianne_BilstedWiese
Hi Forum
I have a versioned database, where I want to make short lines longer. So in Python I try to select the short lines like this
 >>> uCursor = arcpy.da.UpdateCursor(inFeatures, [ 'OID@', 'SHAPE@', 'GM_LABEL', 'GM_USER_DEF' ], 'SHAPE@LENGTH < 300' ) edit = arcpy.da.Editor(arcpy.env.workspace) edit.startEditing() edit.startOperation()
which goes without problems but on
line = uCursor.next()
I get this error
Runtime error  Traceback (most recent call last):   File "<string>", line 1, in <module> RuntimeError: Underlying DBMS error [ORA-04054: databaselink LENGTH does not exist ] [G100.geopoint_line]
I tried also this where clause, that works in ArcMap Select by attributes:
SHAPE.LEN < 300
Because there is also a field called SHAPE.LEN.
I tried with and without quotes with no success.
Is it possible at all to make a constraint based on geometry?
/Marianne
JakeSkinner
Esri Esteemed Contributor
Hi Marianne,
You will want to use the field name in the where clause.  Ex:
uCursor = arcpy.da.UpdateCursor(inFeatures, [ 'OID@', 'SHAPE@', 'GM_LABEL', 'GM_USER_DEF' ], 'SHAPE.LEN < 300' )
JakeSkinner
Hi Marianne,
XanderBakker
Hi Marianne,
What you could also try is to use the properties of the data you're accessing. So read the "lengthFieldName" properties after doing a describe on your data:
desc = arcpy.Describe(inFeatures)
fldLength = desc.lengthFieldName
Next, construct the expression. Make use of "AddFieldDelimiters" which will add the appropriate field delimiter if necessary:
minLength = 300
expression = "{0} < {1}".format(arcpy.AddFieldDelimiters(inFeatures, fldLength), minLength)
In my (non-versioned) SDE the expression will be:
"Shape.len" < 300
In a FGDB it will be:
Shape_Length < 300
Then continue with the UpdateCursor:
fields =  ['OID@', 'SHAPE@', 'GM_LABEL', 'GM_USER_DEF']
uCursor = arcpy.da.UpdateCursor(inFeatures, fields, expression)
Kind regards,
Xander
Hi Marianne,
Oh, simple as that!
Works like a charm, thanks.
-- But where is the 'accepted answer' button?
And also thanks, xander, this might be useful another time
/Marianne
