I don't mind posting the whole thing actually. Not quite as many comments as I would like in it, but if you have questions about how any of it works let me know.
The following script loops through features in a single shapefile or gdb with the particular fields I need, and uses those field values with several premade map templates to create a series of 3 maps for each feature in the shapefile or FC. Each template already has all layers needed saved to it, as well as text elements created and named, but the values of these elements will change according to the field values. All filepaths have been replaced with a generic filepath/ for my sake. Important to note, I had to make a specific folder structure for how I wanted all the maps and pdfs saved prior to running this script, there are other ways to make sure they are created as a script such as this runs, but making it prior was easier.
#Importing Modules
import arcpy, time
#Checking start time
print time.time()
#Permanent Variables
shp = r"filepath\Export_Output.shp"
symbologyLayer = r"filepath\Test.lyr"
symbologyLayer2 = r"filepath\Test2.lyr"
outlayer = shp + "_lyr"
Month = "February"
Year = "2015"
OutputLoc = r"filepath" + "\\"
DPI = 200
#fields from feature class that will be used for text elements/file naming
fields = [ "Acreage", "City", "County" , "Name" , "State", "ED_Region", "ID"]
#Looping through each record in shapefile or feature class
with arcpy.da.SearchCursor(shp, fields) as cursor:
for row in cursor:
if row[4] == "MS":
pass
else:
SiteName = row[3]
State = row[4]
City = row[1]
County = row[2]
Acres = row[0]
Region = row[5]
Hectares = str(int(int(Acres) * .4047))
Acres = str(int(Acres))
ID = row[6]
#Optional output additions for additional subfolders.
Output = OutputLoc + Region + "\\" + County + "\\"
FileName = County + "_" + SiteName + "_" + str(ID)
Title = "Aerial Imagery & FEMA 100 Year Floodplain"
Fullpath = Output + FileName
#Assembling Map - Selecting MXD, Dataframe, and New Layer for Aerial Map w/floodplain
mxd = arcpy.mapping.MapDocument(r"filepath\AerialLetterTemplate.mxd")
df = arcpy.mapping.ListDataFrames(mxd,"*")[0]
newlayer = arcpy.mapping.Layer(shp)
print "adding layer"
arcpy.mapping.AddLayer(df, newlayer, "TOP")
Layer = arcpy.mapping.ListLayers(mxd, newlayer.name)[0]
#Selecting by Attribute, Zooming to Feature, and Setting Scale
arcpy.SelectLayerByAttribute_management(Layer, "NEW_SELECTION", ' "Name" = ' + "'" + SiteName + "'" )
#Symbology from default lyr file
arcpy.ApplySymbologyFromLayer_management (Layer, symbologyLayer)
df.zoomToSelectedFeatures()
print "Zooming to scale"
#I set all my scales by multiples of 1200, engineers love this, I take the initial zoom scale, round it to nearest integer, then zoom it out an additional 1200
df.scale = ((round(df.scale / 1200.0) * 1200) + 1200)
if df.scale == 8400:
df.scale = 9600
arcpy.SelectLayerByAttribute_management(Layer, "CLEAR_SELECTION")
#Editting Text Elements, names for text elements are hardcoded into the map
print "Setting Text Elements"
Layer2 = arcpy.mapping.ListLayoutElements(mxd, "TEXT_ELEMENT" , "Site Name and Size") [0]
Layer2.text = SiteName + "\n" + " \n+/-" + Acres + " Acres \n +/-" + Hectares + " Hectares"
Layer3 = arcpy.mapping.ListLayoutElements(mxd, "TEXT_ELEMENT" , "Title") [0]
Layer3.text = Title + "\n" + SiteName + "\n" + City + ", " + State + " (" + County + " Co.)"
Layer4 = arcpy.mapping.ListLayoutElements(mxd, "TEXT_ELEMENT" , "Prepared by Date") [0]
Layer4.text = "Prepared " + Month + " " + Year + " by:"
arcpy.RefreshActiveView()
#Saving and Exporting Map
print "Saving Map"
print Fullpath + "_Aerial.mxd"
#mxd.saveACopy(OutputLoc + SiteName +" - Aerial.mxd")
mxd.saveACopy(Fullpath + "_Aerial.mxd")
print "Saving PDF"
#arcpy.mapping.ExportToPDF(mxd, OutputLoc + SiteName + " _ Aerial.pdf", "Page_Layout", 640, 480, DPI)
arcpy.mapping.ExportToPDF(mxd, Fullpath + "_Aerial.pdf", "Page_Layout", 640, 480, DPI)
print "Save Complete!"
del Layer; del Layer2; del Layer3; del Layer4; del mxd
print time.time()
print "Next Map"
mxd = arcpy.mapping.MapDocument(r"filepath\TopoLetterTemplate.mxd")
print Layer.name
Title = "USGS Topo Map & NWI Wetlands"
#Applying Symbology from default lyr file
df.scale = 9600
#Setting Layer and Text Elements
WetlandLayer = arcpy.mapping.ListLayers(mxd, "*" + State, df)[0]
WetlandLayer.visible = True
Layer2.text = SiteName + "\n" + " \n+/-" + Acres + " Acres \n+/-" + Hectares + " Hectares"
mxd.saveACopy(Fullpath + "_Topo.mxd")
print "Saving PDF"
#arcpy.mapping.ExportToPDF(mxd, OutputLoc + SiteName + " - Aerial.pdf", "Page_Layout", 640, 480, DPI)
arcpy.mapping.ExportToPDF(mxd, Fullpath + "_Topo.pdf", "Page_Layout", 640, 480, DPI)
del Layer; del Layer2; del Layer3; del Layer4; del WetlandLayer; del mxd
mxd = arcpy.mapping.MapDocument(r"filepath\LocationLetterTemplate.mxd")
Title = "Site Location Map"
#This map has multiple dataframes, which I need to loop through
for df in arcpy.mapping.ListDataFrames(mxd):
if df.name == "Area Map":
OutLayer = "OutLayer_lyr1"
print Layer.name
print "Making Feature Layer"
arcpy.MakeFeatureLayer_management(Layer, OutLayer)
OutLayer2 = arcpy.mapping.Layer(OutLayer)
arcpy.mapping.AddLayer(df, OutLayer2, "TOP")
print "Removing Old Layer"
Layer3 = arcpy.mapping.ListLayers(mxd, OutLayer2)[0]
arcpy.ApplySymbologyFromLayer_management (Layer3, symbologyLayer)
df.scale = 126720
arcpy.mapping.RemoveLayer(df, Layer)
del Layer;
elif df.name == "Inset":
Layer = arcpy.mapping.ListLayers(mxd, newlayer.name, df)[0]
OutLayerA = "OutLayer_lyr2"
print Layer.name
arcpy.MakeFeatureLayer_management(Layer, OutLayerA)
OutLayerC = arcpy.mapping.Layer(OutLayerA)
arcpy.mapping.AddLayer(df, OutLayerC, "TOP")
OutLayerB = arcpy.mapping.ListLayers(mxd, OutLayerC.name)[0]
arcpy.ApplySymbologyFromLayer_management (OutLayerB, symbologyLayer2)
df.scale = 2300000
del OutLayer2; del OutLayerC; del OutLayerB; del Layer3
else:
continue
mxd.saveACopy(Fullpath + "_Location.mxd")
print "Saving PDF"
arcpy.mapping.ExportToPDF(mxd, Fullpath + "_Location.pdf", "Page_Layout", 640, 480, DPI)
del Layer; del Layer3; del Layer4; del mxd;
arcpy.Delete_management(OutLayer)
arcpy.Delete_management(OutLayerA)
print time.time()
del shp
