Cursor Not Working
9312
12
11-18-2016 07:59 AM
alysaochoa2
Hi everyone,
I'm writing a script to plot points and then delete rows that have a value of less than 5.
the script
I am getting the following error on the cursor lines:
File "C:\Users\30030839\Favorites\Downloads\pyfinal2.py", line 32, in <module>
cursor = arcpy.da.UpdateCursor("C:\\Users\\30030839\\Desktop\\Python\\capacity_points_layer2", ["DEM"])
RuntimeError: cannot open 'C:\Users\30030839\Desktop\Python\capacity_points_layer2'
I'm not sure why this file isn't able to open. It's not being used in any application, and its folder is not open.I added the file to ArcMap previously to make sure the shapefile worked and that the attribute table exists, and it's fine. Does anyone know why I would be getting this error?
JoshuaBixby
MVP Esteemed Contributor
You are misunderstanding the documentation.  A "layer" and "layer file" are not synonymous.  Cursors can work on datasets directly or layers/views of datasets, cursors do not work directly against layer files.  If you want to use a layer file, first use Make Feature Layer (if spatial) or Make Table View to create a layer and then pass that layer to the cursor.
alysaochoa2
Hi All,
Converting my layer to a feature class and referencing that feature class in the cursor worked!
Thank you so much for all of your help.
-AO
alysaochoa2
Final completed script with no errors:
