Creating Point Feature Class from Fields in Table
1276
11-14-2013 05:10 PM
NumaGremling
Hi everyone one,
I wrote a script that searches Tweets and writes them to a table in a geodatabase. I got this to work finally, and now I would like to map out the tweets that have a location attached to them.
As you can see in the following screenshot, I have a latitude and longitude field already:
[ATTACH=CONFIG]29125[/ATTACH]
What would be the best approach to use these two fields and create a point feature class? I initially was thinking about Add XY, but I do not think that works with my data. I stumbled upon tokens (SHAPE@XY, for instance), and I was wondering if that might be what I need to implement.
Here is my current cursor in case that helps:
cursor = arcpy.da.InsertCursor("E:/Redlands/MIP/Files/Twitter.gdb/TweetTable4", ("DateRun", "Username", "GeoEnabled", "Coordinates", "Latitude", "Longitude", "PostTime", "Tweet"))
Any advice is appreciated. Thank you!
NumaGremling
Problem solved; figured it out after more browsing.
In case anyone is interested, I first used Make XY Event Layer, which is a temporary layer, and then I saved it to a feature class, using Feature To Point.
        # Define input parameters
    inputTable = "E:/Redlands/MIP/Files/Twitter.gdb/TweetTable"
    xLong = "Longitude"
    yLat = "Latitude"
    outputLayer = "tweet_pts"
        # Create layer with above inputs
    arcpy.MakeXYEventLayer_management(inputTable, xLong, yLat, outputLayer)
         # Save the event layer as a feature class
    arcpy.FeatureToPoint_management(outputLayer, "E:/Redlands/MIP/Files/Twitter.gdb/TweetPoints")
