Creating an OLE DB connection to a SQLServer database
7740
03-27-2012 07:23 AM
ClaireParsons
Hi
I'm fairly new to Python, so please bear with me.
I need to create a link to a SQLServer database using OLEDB and i haven't got a clue where to start.
Can someone help please? 😞
Many thanks
Claire
KeithSandell
Start here: http://code.google.com/p/pyodbc/
You'll have to download and install pyodbc, make sure you get the version that matches the python version you have installed, most likely the version that installed with ArcGIS.
import arcpy, pyodbc
cnxn = DRIVER={SQL Server};SERVER=cloak;DATABASE=test;UID=user;PWD=password
cursor = cnxn.cursor()
cursor.execute("{any legal SQL stmt you would execute in SSMS}")
cnxn.commit()
I use it to get the functionality out of ArcGIS and the speed of SQL.
JamesCrandall
cnxn.commit()
Have you or others experienced issues of secondary runs when pyodbc is run from ArcGIS/ArcCatalog(9.3.1) Toolbox?
I get a 9999998 Error when the script/tool with pyodbc is run a second time.
note: I don't have this issue with cx_Oracle. Just exploring alternative ways to connect to non-spatial data repositories.
JamesCrandall
Apparently ArcCatalog simply doesn't like pyodbc all that much.  Supposedly it has to do with the way ArcCatalog handles conneciton pooling.
...sticking with cx_Oracle for the time being.
