Creating a file for an ODBC Connection
1828
07-08-2011 03:17 PM
HunterBarcello
I have a script that copies multiple tables from an ODBC connection to a geodatabase and then uses some other tables from the same connection to update a feature class within the same geodatabase.
I know that for SDE connections you can create a connection file so that you can reference a particular file location for your connection.  Helpful so that other uses who might not have the connection set up in their own ArcCatalog.  Is there a way to do this with ODBC connections as well?  I am trying to get these scripts set up so that anyone in my organization can run them.
