CreateRelationshipClass with MANY_TO_MANY - how?
1238
11-17-2025 12:44 AM
nadja
I'm trying to create several Relationship Classes with the cardinalities 1:1 and n:n. The below script works fine with my 1:1 relationship classes. It runs also for the n:n cardinalities, creates some relationship classes, but I can't access its values with the explore tool as with the 1:1 relationship classes. Why? What's wrong?
for index, row in df.iterrows():
    arcpy.management.CreateRelationshipClass(origin_table = row["origin_table"],
                                            destination_table = row["destination_table"],
                                            out_relationship_class = row["out_relationship_class"],
                                            relationship_type = row["relationship_type"],
                                            forward_label = row["forward_label"],
                                            backward_label = row["backward_label"],
                                            message_direction = row["message_direction"],
                                            cardinality = row["cardinality"],
                                            attributed = row["attributed"],
                                            origin_primary_key = row["origin_primary_key"],
                                            origin_foreign_key = row["origin_foreign_key"],
                                            destination_primary_key = row["destination_primary_key"],
                                            destination_foreign_key = row["destination_foreign_key"])
with my table:
origin_tabledestination_tableout_relationship_classrelationship_typeforward_labelbackward_labelmessage_directioncardinalityattributedorigin_primary_keyorigin_foreign_keydestination_primary_keydestination_foreign_key
mgdm_polygone_polygonmgdm_polygone_regelpolygon_regelSIMPLERegelpolygonNONEMANY_TO_MANYNONERegelRegelRegelCode#
TonyAlmeida
MVP Regular Contributor
ArcGIS creates intermediate relationship table that stores the pairs of related objects. Unlike 1:1 relationships, you cannot directly access related records through the Explore tool without this intermediate table.
Try something like this.
import arcpy
import os
def create_relationship_with_intermediate_check(row):
    """Create relationship class and handle intermediate table for n:n"""
    # Create the relationship class
        origin_table=row["origin_table"],
        destination_table=row["destination_table"],
        out_relationship_class=row["out_relationship_class"],
        relationship_type=row["relationship_type"],
        forward_label=row["forward_label"],
        backward_label=row["backward_label"],
        message_direction=row["message_direction"],
        cardinality=row["cardinality"],
        attributed=row["attributed"],
        origin_primary_key=row["origin_primary_key"],
        origin_foreign_key=row["origin_foreign_key"],
        destination_primary_key=row["destination_primary_key"],
        destination_foreign_key=row["destination_foreign_key"]
    # Handle n:n specific setup
    if row["cardinality"].upper() == "MANY_TO_MANY":
        handle_many_to_many_relationship(row)
def handle_many_to_many_relationship(row):
    """Locate and verify the intermediate table for an n:n relationship class."""
    print(f"n:n Relationship created: {relationship_class}")
    # Describe the relationship class
    desc = arcpy.Describe(relationship_class)
    # ArcGIS tells us exactly which table is the join table
    rel_table_path = desc.relationshipTable
    if not rel_table_path:
        print("No intermediate relationship table found (Describe returned None).")
        return
    print(f"Intermediate table located: {rel_table_path}")
    # Verify it exists
    if arcpy.Exists(rel_table_path):
        print("Intermediate relationship table verified")
        # Inspect fields
        rel_desc = arcpy.Describe(rel_table_path)
        fields = [f.name for f in rel_desc.fields]
        print(f"Relationship table fields: {fields}")
    else:
        print("Relationship table path does not exist in the workspace.")
nadja
Thank you @TonyAlmeida. If I understand your code correctly, this assumes that there already is an intermediate relationship table, correct? how do you create such a table? I found https://pro.arcgis.com/en/pro-app/3.4/tool-reference/data-management/table-to-relationship-class.htm, but this gp tool too assumes there is already such an intermediate table.
TonyAlmeida
Yes, the code assumes the intermediate table already exists.
But ArcGIS automatically creates the intermediate table for you when BOTH of the following are true:
cardinality = "MANY_TO_MANY"
attributed = "NONE" (i.e., NOT attributed)
nadja
I get an error if i try to access the relationshipTable from a RelationshipClass using
print(rc.relationshipTable)
AttributeError: DescribeData: Method relationshipTable does not exist
TonyAlmeida
Try this,
Set the parameter values to:
attributed = "NONE"
and
row dictionary contains:
row["cardinality"] = "MANY_TO_MANY"
row["attributed"] = "NONE"
import arcpy
import os
    # Should auto-create the join table
        row["attributed"] = "NONE"  # REQUIRED for system-generated table
    # Handle M:N after creation
    """Locate and verify the intermediate table for an n:n (non-attributed) relationship."""
    # SAFE ATTRIBUTE CHECK
    if hasattr(desc, "relationshipTable"):
    else:
        print("No system-generated intermediate table exists (attributed=ATTRIBUTED or invalid RC).")
        return
        print("Describe returned a blank relationshipTable property.")
        return
        print("Intermediate table verified.")
        # List fields
        fields = [f.name for f in arcpy.ListFields(rel_table_path)]
    else:
        print("Relationship table does not exist in the workspace.")
