Thanks for following up with on your original comment. I am going to be attempting to do something similar and spent some time formatting the code as I tried to follow it.
Here it is. I think I got the indentations right...
if anyone notices errors let us know.
I assume there is a way to update the vtpk source in portal.
Created on Wed Jun 26 13:10:43 2019
******not my code*****
source https://community.esri.com/thread/210061-create-vector-tile-package-different-results-in-arcgis-pro-and-standalone-python-script
import os
import logging
import logging.handlers
import datetime
import configparser
import SendEmail
from arcgis.gis import GIS
import arcpy
import sys
def getMapProperties(mapPropsList):
mapProperties = {}
for i in range(0, len(mapPropsList)):
props = mapPropsList[i].split(",")
mapname = props[0]
mapnameupper = mapname.upper()
mapProperties[mapnameupper] = {}
mapProperties[mapnameupper]['mapname'] = props[0]
if len(props) > 1:
mapProperties[mapnameupper]['minscale'] = props[1]
else:
mapProperties[mapnameupper]['minscale'] = ""
if len(props) > 2:
mapProperties[mapnameupper]['maxscale'] = props[2]
else:
mapProperties[mapnameupper]['maxscale'] = ""
if len(props) > 3:
mapProperties[mapnameupper]['vtpkindex'] = props[3]
else:
mapProperties[mapnameupper]['vtpkindex'] = ""
return mapProperties
def createVtpk(m, mapProperties, indexGDBPath, vtpkPath, logger):
mapName = m.name
minscale = ""
maxscale = ""
vtpkindexfile = ""
mapNameUpper = mapName.upper()
if mapNameUpper in mapProperties:
minscale = mapProperties[mapNameUpper]['minscale']
if minscale != "":
minscale = float(minscale)
maxscale = mapProperties[mapNameUpper]['maxscale']
if maxscale != "":
maxscale = float(maxscale)
vtpkindex = mapProperties[mapNameUpper]['vtpkindex']
if vtpkindex != "":
vtpkindexfile = os.path.join(indexGDBPath, vtpkindex)
logger.info("Creating Vector Tiles for " + mapName)
arcpy.management.CreateVectorTilePackage(m, vtpkPath, "ONLINE", "", "INDEXED",
minscale, maxscale, vtpkindexfile)
return vtpkPath
return ""
def uploadVtpk(gis, vtpkName, vtpk, logger):
vtpkFile = gis.content.search(query="title:"+vtpkName,
item_type="Vector Tile Package")
for i in range(0, len(vtpkFile)):
item = vtpkFile[i]
if item.title.upper() == vtpkName.upper():
logger.info("Deleting Old VTPK Package From Portal")
item.delete()
break
logger.info("Uploading VTPK package")
vtpk_item = gis.content.add({}, data=vtpk)
if vtpk_item is None:
logger.error("Error adding " + vtpk + " to Portal")
return vtpk_item
def publishVtpk(gis, vtpkName, vtpk_item, portalGroups, logger):
vtpkLayer = gis.content.search(query=vtpkName, item_type="Vector Tile Service")
for i in range(0, len(vtpkLayer)):
vLayer = vtpkLayer[i]
if vLayer.title.upper() == vtpkName.upper():
logger.info("Deleting Old VTPK Service From Portal")
vLayer.delete()
break
logger.info("Publishing VTPK service")
vtpk_service = vtpk_item.publish()
vtpk_item.delete()
logger.info("Sharing to Group in Portal")
for group in portalGroups:
cp_group = gis.groups.search('title:' + group, max_groups=15)
for i in range(0, len(cp_group)):
cpgroup_share = cp_group[i]
if cpgroup_share.title.upper() == group.upper():
vtpk_service.share(groups=cpgroup_share.id)
break
return vtpk_service
def SendErrorNotification(emailTo, emailFrom, msg):
for email in emailTo.split(";"):
SendEmail.email_error_msg(emailTo, emailFrom, msg)
def main():
if len(sys.argv) == 1:
print("Please provide parameter for config file")
sys.exit()
if not os.path.isfile(sys.argv[1]):
print("Config file does not exist")
sys.exit()
cfile = configparser.ConfigParser()
cfile.read(sys.argv[1])
portalUrl = cfile.get('Portal', 'PortalUrl')
portalGroupsList = cfile.get('Portal', 'PortalGroup')
portalGroups = portalGroupsList.split(";")
workspace = cfile.get('Folder', 'Workspace')
outputPath = cfile.get('Folder', 'OutputFolder')
logFile = cfile.get('Folder', 'LogFile')
emailTo = cfile.get('Notification', 'EmailTo')
emailFrom = cfile.get('Notification', 'EmailFrom')
vtpkIndexFolder = cfile.get('VTPK', 'VtpkIndexFolder')
project = cfile.get('VTPK', 'ProProject')
mapProps = cfile.get('VTPK', 'MapProperties')
mapProperties = getMapProperties(mapProps.split(';'))
logger = logging.getLogger('vectortiles_oca')
logger.setLevel(logging.INFO)
formatter = logging.Formatter('%(asctime)s - %(levelname)s - %(message)s')
handler = logging.handlers.RotatingFileHandler(logFile,
maxBytes=100000,
backupCount=5)
handler.setFormatter(formatter)
logger.addHandler(handler)
gis = GIS(portalUrl, verify_cert=False)
arcpy.env.workspace = workspace
arcpy.env.overwriteOutput = True
arcpy.env.parallelProcessingFactor = "66%"
logger.info("XXXXXXXXXXXXXXXXXXXXXXXX=Start")
p = arcpy.mp.ArcGISProject(project)
maps = p.listMaps("*")
for i in range(0, len(maps)):
try:
if maps[i].name.upper() in mapProperties:
vtpk = os.path.join(outputPath, maps[i].name + '.vtpk')
if os.path.exists(vtpk):
backupPath = os.path.join(outputPath, "backup")
newname = os.path.join(backupPath, maps[i].name + '_' +
datetime.datetime.today().strftime('%Y%m%d%H%M')
+ '.vtpk')
logger.info("Renaming existing VTPK to " + newname)
os.rename(vtpk, newname)
tryagain = True
count = 0
while tryagain:
count = count + 1
if count == 5:
break
try:
vtpkPath = createVtpk(maps[i], mapProperties, vtpkIndexFolder,
vtpk, logger)
vtpk_item = uploadVtpk(gis, maps[i].name, vtpk, logger)
publishVtpk(gis, maps[i].name, vtpk_item, portalGroups, logger)
tryagain = False
except Exception as e:
logger.error(e, exc_info=True)
if count == 3:
"Encountered an error - "
+ maps[i].name
+ ". trying again." + str(e))
"Vector Tiles Script has failed for map " +
maps[i].name + ": " + str(e))
del gis
logger.info("XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX=Complete")
if __name__ == '__main__':
main()
