Create variable with Cursor and write it in a text file with Python
8525
15
05-28-2015 05:37 AM
KONPETROV
Hi, i am trying to create three variables from a table and write them in a text file with Python. These variables are values from the first row of three fields. I tried it with Search Cursor but i can get only the first variable, i don't know why. Next i am trying to do the same with a folder of polylines taking the first row of 2 fields using the same text i created above but unsuccesfully. Any suggestion would be great. Thanks a lot. This is my code:
import arcpy
import os
from arcpy import env
arcpy.env.workspace = "c:/Win/Sik"
input = "s3s2c10"
fields = ['X', 'Y', 'MOSAIC']
#NEW TXT FILE "MOON"
outFile = open("c:/Win/Sik/moon.text", "w")
with arcpy.da.SearchCursor(input, fields, 'OID = 1') as cursor:
    X = row[0]
    Y = row[1]
    IPSOS = row[2]
outFile.write('x is '+str(X)+'meters,'\n' Y is'+str(Y)+'and '\n' ipsos is'+str(IPSOS))
outfile.close()
import arcpy
import os
arcpy.env.workspace = "c:Win/Sik/True
featureclasses = arcpy.ListFeatureClasses("Truelines", "Polyline", "")
for fc in featureclasses:
    TIME = row[0]
    DISTANCE = row[1]
outFile.write( '\n''\n' 'TIME is '+str(TIME)+'meters,'\n' and DISTANCE is'+str(DISTANCE)+'meters'
outfile.close()
KONPETROV
Thank you Owen. It's just that i haven't used again two different workspaces inside a script.
Except from that for the iteration of shapefiles this is the code:
import arcpy
import os
arcpy.env.workspace = "c:Win/Sik/Routes"
featureclasses = arcpy.ListFeatureClasses("RT", "Polyline", "")
    fields = ['DISTANCE', 'DURATION']
    with arcpy.da.SearchCursor(fc, fields, "FID = 0") as cursor:
        for row in cursor:
            TIME = row[0]
            DISTANCE = row[1]
outFile.write('TIME is ' + str(TIME) + 'meters,\n Y is' + str(DISTANCE) + 'and \n ipsos is' + str(DISTANCE))
outfile.close()
but i get back that error
Runtime error
  File "<string>", line 7, in <module>
TypeError: 'NoneType' object is not iterable
although i have defined the type of shapefiles
KONPETROV
What does is it mean, "is not iterable"? How can that be?
BillDaigle
I think the arcpy.ListFeatureClasses command is returning None (which is not iterable) because the workspace is not getting set correctly in line 4.  Try updating line 4 to:
arcpy.env.workspace = "c:/Win/Sik/Routes"
KONPETROV
i did it already Daigle, but still remains. I also applied this
import arcpy
... import os
... from arcpy import env
... arcpy.env.workspace = "c:/Win/Sik/Routes"
... outFile = open("c:/Win/Sik/moon.text", "w")
... featureclasses = arcpy.ListFeatureClasses("RT", "Polyline")
... for fc in featureclasses:
...     fields = ['DISTANCE', 'DURATION']
...     with arcpy.da.SearchCursor(fc, fields, "FID = 0") as cursor:
...         for row in cursor:
...             outFile.write('distance is ' + str(row[0]) + 'meters,\n duration is' + str(row[1])
... outFile.close()
but either it returns nothing or overwrites the previous results from text file leaving an empty file
KONPETROV
I think i found it! The wildcard(*) for God. Now can i put these to scripts to be together as one or the second will overwrite the first?
mm.png.
curtvprice
Two issues with OID = 1 worth noting I think:
1. You can get the name o the object ID field (which can vary by data source and sometimes by workflow) you can do this:
OIDField  = arcpy.Describe(lyr).OIDFieldName
2. The first row can be object ID zero or one, depending on data source. If what you want the first row, I'd do this instead:
row = arcpy.da.SearchCursor(input, fields).next()
print row
