Create variable with Cursor and write it in a text file with Python
8590
15
05-28-2015 05:37 AM
KONPETROV
Hi, i am trying to create three variables from a table and write them in a text file with Python. These variables are values from the first row of three fields. I tried it with Search Cursor but i can get only the first variable, i don't know why. Next i am trying to do the same with a folder of polylines taking the first row of 2 fields using the same text i created above but unsuccesfully. Any suggestion would be great. Thanks a lot. This is my code:
import arcpy
import os
from arcpy import env
arcpy.env.workspace = "c:/Win/Sik"
input = "s3s2c10"
fields = ['X', 'Y', 'MOSAIC']
#NEW TXT FILE "MOON"
outFile = open("c:/Win/Sik/moon.text", "w")
with arcpy.da.SearchCursor(input, fields, 'OID = 1') as cursor:
    X = row[0]
    Y = row[1]
    IPSOS = row[2]
outFile.write('x is '+str(X)+'meters,'\n' Y is'+str(Y)+'and '\n' ipsos is'+str(IPSOS))
outfile.close()
import arcpy
import os
arcpy.env.workspace = "c:Win/Sik/True
featureclasses = arcpy.ListFeatureClasses("Truelines", "Polyline", "")
for fc in featureclasses:
    TIME = row[0]
    DISTANCE = row[1]
outFile.write( '\n''\n' 'TIME is '+str(TIME)+'meters,'\n' and DISTANCE is'+str(DISTANCE)+'meters'
outfile.close()
DarrenWiens2
Check that your input shapefile indeed has a field called 'OID' and not the more usual 'FID' field.
Compare:
>>> arcpy.env.workspace = r"C:\junk"
... input = "points"
... fields = ['heading','distance']
... with arcpy.da.SearchCursor(input,fields,"OID = 1") as cursor:
...     for row in cursor:
...         print row
Runtime error
  File "<string>", line 5, in <module>
RuntimeError: A column was specified that does not exist.
... with arcpy.da.SearchCursor(input,fields,"FID = 1") as cursor:
...         print row
(192, 533)
LukeWebb
For the 1st part (and the 2nd but well get to that later), you dont define 'row' anywhere, so I dont know where its getting the variable from!
To correct try adding the line 'for row in cursor:' as I have below:
import arcpy
import os
input = "s3s2c10"
    for row in cursor:
        X = row[0]
        Y = row[1]
        IPSOS = row[2]
outfile.close()
KONPETROV
Luke i am getting a
Runtime error Traceback (most recent call last):   File "", line 12, in RuntimeError: A column was specified that does not exist.
but i cannot understand why
JakeSkinner
Esri Esteemed Contributor
Hi Kon,
For your search cursor, try the following:
    for row in cursor:
        X = row[0]
        Y = row[1]
        IPSOS = row[2]
For the folder of polyline feature classes, if there are many feature classes you are trying to iterate through, you will want to use a wildcard.  You existing syntax will only find a feature class called 'Truelines'.  You may want to add try '*'.  This will iterate through all of the feature classes in the workspace.  Ex:
featureclasses = arcpy.ListFeatureClasses("*", "Polyline", "")
    with arcpy.da.SearchCursor(fc, fields) as cursor:
        for row in cursor:
            TIME = row[0]
            DISTANCE = row[1]
outfile.close()
KONPETROV
Jake with the first block i am getting the same error as in Luke:
For the second block of code, "Trueline" is my wildcard. And i have  ap problem with the last line cause  i am getting an error
Parsing error SyntaxError: invalid syntax (line 12)
DarrenWiens2
Compare:
...         print row
Runtime error
...         print row
(192, 533)
KONPETROV
Οh, god. Yes you are right about that,  table has a Rowid starting from 1 and Polyline an FID starting from 0. But i am still getting an error Parsing error SyntaxError: unexpected character after line continuation character (line 17)
when i run it inside outfile to write it in my text.
DarrenWiens2
I don't believe you need all the quotes around the \n's:
outFile.write('x is ' + str(X) + 'meters,\n Y is' + str(Y) + 'and \n ipsos is' + str(IPSOS))
KONPETROV
and of course you were right again! I have two last questions, can i have these two scripts together as a tool because these are two different workspaces.? How can i pass also the name of each shp ?
OwenEarley
To pass in the names of the shapefiles you can use arcpy.GetParameterAsText(). For an outline of how to do this see these pages:
Using parameters you could also pass in the different workspaces and switch between them when required.
