Create shape file of bookmark extents and/or automatically print bookmark extents to
1846
05-17-2011 04:22 PM
George_ChandeepCorea
Is it possible to export the extents of all bookmarks in an active map document to a shape file containing the polygons of the shape and/or to automate the print to pdf of all the bookmark extents?
I would like to get armap to print all the bookmarks and update text elements (the latter I can write).
The code for doing this with extents at http://gis.stackexchange.com/questions/9518/how-do-i-insert-a-dataframe-element-value-into-a-dynamic...
Thanks in advance
ChrisMathers
The MapDocument object has no access to the bookmarks saved in the document. You can view/edit the extent of a DataFrame object but no extents are exposed beyond the current one.
