Create Relationship Class
1244
07-07-2023 11:08 AM
kapalczynski
Im confused.  I have a python file that creates a Relationship Class on my DEV and TEST server.  Everything works fine on that Server
Note: that the same user and permissions are being used to run the python script on all servers.
I use the SAME code on my UAT and PROD server and I get an error:
ExecuteError: Failed to execute. Parameters are not valid
ERROR 000800: The Value is not a member of GLOBALID
Failed to execute (Create Relationship Class)
ANY THOUGHTS?
import arcpy
arcpy.env.workspace = "Database Connections\\GIS_DEV@gis_data.sde"
def createRelationships():
    print("")
    arcpy.CreateRelationshipClass_management(origin_table="Database Connections\\GIS_DEV@gis_data.sde\\GIS_DATA.SDE_AAH",
           destination_table="Database Connections\\GIS_DEV@gis_data.sde\\GIS_DATA.TBL_AAH_Pickups",
           out_relationship_class="Database Connections\\GIS_DEV@gis_data.sde\\GIS_DATA.REL_AAH_TO_PICKUP",
           relationship_type="COMPOSITE",
           forward_label="GIS_DATA.TBL_AAH_Pickups",
           backward_label="GIS_DATA.SDE_AAH",
           message_direction="NONE",
           cardinality="ONE_TO_MANY",
           attributed="NONE",
           origin_primary_key="GLOBALID",
           origin_foreign_key="GUID",
           destination_primary_key="",
           destination_foreign_key="")
if __name__ == '__main__':
    # Create Relationships
kapalczynski
If I go to the server and use the same credentials I can do this manually via ArcCatalog... wondering why its not working with Python
kapalczynski
Anyone have any thoughts on this error?
