Create Raster Dataset fail
1499
08-15-2012 07:31 AM
RichardThurau
Simple python code, keeps failing, not sure what's happening. Any help is much appreciated.
CoordSys = r"C:\Program Files\ArcGIS\Desktop10.0\Coordinate Systems\Projected Coordinate Systems\UTM\NAD 1983\NAD 1983 UTM Zone 11N.prj" LCOutDir = r"E:\Projects\TV\TV_Trees_working.gdb" arcpy.env.workspace = LCOutDir SmallTree_mosaic1 = os.path.join(LCOutDir, "SmallTree_mosaic1")   arcpy.CreateRasterDataset_management (LCOutDir, SmallTree_mosaic1, 1, "8_BIT_UNSIGNED", CoordSys, 1, "", "PYRAMIDS 0", "", "NONE", "")
Error message:
  File "E:\Projects\TV\01_Python\LandCover\rtc_LC_2.0.2_Tile_Trees_081412.py", line 50, in <module>
    arcpy.CreateRasterDataset_management (LCOutDir, SmallTree_mosaic1, 1, "8_BIT_UNSIGNED", "", 1, "", "PYRAMIDS 0", "", "NONE", "")
  File "C:\Program Files\ArcGIS\Desktop10.0\arcpy\arcpy\management.py", line 7062, in CreateRasterDataset
    raise e
ExecuteError: ERROR 999999: Error executing function.
Failed to execute (CreateRasterDataset).
Rich
JakeSkinner
Esri Esteemed Contributor
Hi Richard,
It looks like you are specifying the full path of the new raster in the second parameter of the Create Raster function.  This parameter will only require the name of the new raster.  Try the following instead:
arcpy.CreateRasterDataset_management(LCOutDir, "SmallTree_mosaic1", 1, "8_BIT_UNSIGNED", CoordSys, 1, "", "PYRAMIDS 0", "", "NONE", "")
JakeSkinner
Hi Richard,
RichardThurau
J,
Awesome, thanks. Works great now.
RT
