Create Personal GeodataBase in ArcGis 10 compatible to 9.3
1371
06-27-2012 10:37 AM
MoisésCaballero
Hi, can I help me with syntax error. When I run in Geoprocesing window, Python rutine...
import arcpy from arcpy import env arcpy.CreateFileGDB_management (c:/Pru, Dad.mdb, 9.3)
Parsing error <type 'exceptions.SyntaxError'>: invalid syntax (line 1)
I copy the command sequence, to ESRI
import arcpy from arcpy import env  arcpy.CreatePersonalGDB_management("C:/output", "pGDB.mdb", "9.2")
I hope anybody help me, regards and thank you...
KenBuja
MVP Esteemed Contributor
You left off the quotes and if you're using the Create File Geodatabase command, the geodatabase should have the suffix "gdb".
arcpy.CreateFileGDB_management ("C:/Pru", "Dad.gdb", "9.3")
JasonScheirer
Esri Alum
Need to split into multiple lines probably? Also you don't need the "from arcpy import env" line
import arcpy
KenBuja
MoisésCaballero
Ok, that's correct, the two answers complement my question. Thank you for your time, I create succesfully my PGDB.
Science Master Marine Biology
Moises Caballero
INEGI, Mexico
