create new point from centroid grid
1016
12-05-2012 06:42 AM
nimitz
Hey all,
I've been working on creating a point shapefile from the centroid of a polygon grid I created for mapbook purposes. I have a simple script that is coming back with this error:"Traceback (most recent call last):
  File "C:\Users\RLong\Documents\NewPoint.py", line 19, in <module>
    arcpy.FeaturetoPoint_management("GridIndex", "SamplesLoc", "Centroid")
AttributeError: 'module' object has no attribute 'FeaturetoPoint_management'"
Here is my code so far:
###Simple point shape file object for testing
###Import standard modules
import os, sys, math, arcpy, traceback, string, fileinput
###Setup your workspace or file you're going to use
from arcpy import env
arcpy.env.workspace = "C:/Users/RLong/GIS_Data/Conversions/GridIndex.shp"
###Setup Local variables
in_features = "GridIndex.shp"
point_location = "Centroid"
out_feature_class = "SamplesLoc"
###Create the points
Could this error be coming up cuz I don't have arcinfo?
Any help is appreciated,
Randy
ArkadiuszMatoszka
Yes, error shows up because You don't have licence for this tool (Advanced is needed). I think simplest workaround would be using data access search cursor with Shape@centroid and insert cursor to create points.
Cheers.
Arek
