composite bands cannot open input dataset
3724
12-08-2012 07:59 AM
KatSuda
I have been trying to composite 3 bands and keep getting  this error message:
ExecuteError: ERROR 000271: Cannot open the input datasets
Failed to execute (CompositeBands).
I have run several small tests to see if my names were OK - they seem to be.
I have also tried compositing tiffs, grids in a folder and grids in a file geodatabase.  I get the message every time.  I don't see anything in the CompositeBands description that indicates my parameters are off.
Do any of you have some ideas?
Here is the code:
#import system modules
import arcpy, os
from arcpy import env
arcpy.env.workspace = r"C:/FINAL/data.gdb"
#overwrite files with the same name
env.overwriteOutput = True
#list the rasters to be used
#rasters in the geodatabase that start with 't' are 4-band images
rasters= arcpy.ListDatasets("t*", "Raster")
#rasters that start with ,p, are 4-band PCA results
PCA= arcpy.ListDatasets("p*", "Raster")
#make a combination of bands 1,4 and 2nd PC
for raster in rasters:
    raster1= raster + "/Band_1"
    raster4= raster + "/Band_4"
    r_index= raster[1] + raster[3]
    for component in PCA:
        p2= (component, "/Band_2")
        print "processing: " + r_index
        outRaster = ("b14p" + r_index)
        if r_index == component[1:3]:
            arcpy.CompositeBands_management("raster1; raster4; p2", outRaster)
print "Composites complete"
Maybe there's a work-around?
Thanks for any insight.
Kat
edit:  I forgot to say that I am using ArcGIS 10.0 sp1 and that I am running the script as a stand-alone.
Also, I am using Python (IDLE) 2.6.5
KatSuda
I happened across the answer to this after giving up and trying something else.  It turns out that the map document I was re-using over and over for my tests had long ago had a scratch space set by me in a different folder.  And I had deleted that folder somewhere along the line.  So, of course the intermediate files didn't exist!
It was a stupid mistake.  I'm posting for any others new to python.  Just one more thing to check when you get that kind of error.
krs
