Create new label class with python?
5170
10-16-2014 12:56 PM
DerrickKo_Heinrichs
Unsuccessfully trying to create a new label class using python. Forums have been helpful for figuring out python for the label class SQL query & expression, but now I want to add another class with a new query & expression.
DanPatterson_Retired
what example are you working with?
DerrickKo_Heinrichs
Within a forest inventory I want to label certain types of forest polygons differently, as well as wetlands and other non-forest features. How do I post my python script!? (this is my first time posting a question here!)
copy and paste it here then use the Advanced Editor in the top right of the post frame then look for the >> then select syntax highlighting and select python
DerrickKo_Heinrichs
Here's what I've got so far. I'm relatively new to python & have learned by trial & error & reading through these forums. What the below seems to do is rename the 'Default' label class. How do I add a new label class?
# Create Label Class for Single Layer Forested polys
for lyr in arcpy.mapping.ListLayers (mxd):
    if lyr.name == MAPSHEET:
        if lyr.supports("LABELCLASSES"):
            for lblclass in lyr.labelClasses:
                lblclass.showClassLabels = True
        lblclass.className = "FLsingle"
        lblclass.SQLQuery = "\"CANLAY\" = 'S' AND \"US2CANLAY\" IS NULL"
        lblclass.expression = "\"{0}\" + [CANLAY] +  \" - CC:\"  +  [CC] + \"{1}\"".format("<CLR red='0' blue='255' green='0'><FNT size = '11'>","</FNT></CLR>") # expression is currently incomplete
        lyr.showLabels = True
        arcpy.RefreshActiveView()
