Create New Field Issues -- Specify LONG creates DOUBLE
2311
6
01-09-2025 10:50 AM
kapalczynski
I am trying to create a new field in an Enterprise GDB ...
I use the below and for some reason it creates the field with DOUBLE, 38, 8
arcpy.management.AddField(toFeatureClass, "LOCALITY", "LONG", 20, "", "", "Locality", "NULLABLE", "NON_REQUIRED")
DavidSolari
MVP Regular Contributor
I have a feeling specifying a field length is tripping it up. This is what Pro spits out as a default Python command for adding a "Long" field, you should be able to tweak this:
    in_table=toFeatureClass,
    field_name="LOCALITY",
    field_type="LONG",
    field_precision=None,
    field_scale=None,
    field_length=None,
    field_alias="Locality",
    field_is_nullable="NULLABLE",
    field_is_required="NON_REQUIRED",
    field_domain=""
DavidSolari
    field_type="LONG",
    field_scale=None,
    field_length=None,
    field_domain=""
kapalczynski
As I needed 15 digits I had to create a DOULBE with 15 digits and 0 decimal places as LONG only holds 10 digits.
Laura
by MVP Regular Contributor
Long field type I believe doesn't have precision or scale like (double or float) so the 20 would be ignored. Can you try without that?
arcpy.management.AddField(toFeatureClass, "LOCALITY", "LONG", "", "", "", "Locality", "NULLABLE", "NON_REQUIRED")
CodyPatterson
Hey @kapalczynski
It appears that the long will be created as a double if the precision is 11 or more from this documentation here:
https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/add-field.htm
For a field with a scale of 0, use a long or short integer field type. When creating a long integer field, specify a precision of 10 or less, or the field may be created as a double.
Cody
kapalczynski
Thank you all for your comments...
So if I need the field to carry 15 digits I have to make it a DOUBLE with PRECISION of 15 and no DECIMALS?
TonyAlmeida
You must use Double.
    field_type="DOUBLE",  # Use DOUBLE for high-precision numbers
    field_precision=15,   # Total number of digits
    field_scale=0,        # No decimal places
