Create an outline of a raster grid
1218
07-18-2013 01:46 AM
ShaneCarey
I have a raster grid and I need to create a outline from the grid, some areas have No data and I was going to try create an outline using contour, but this will not work for areas of No data.
Any ideas would be appreciated,
Cheers
JamesCrandall
MVP Alum
You can use the Extent of the raster to get the lower-left, lower-right, upper-left, and upper-right points and just add these to a new polyline or polygon feature class.
inputRaster = r"C:\MyRaster"
desc = arcpy.Describe(inputRaster)
ext = desc.extent
ll = ext.lowerLeft
ul = ext.upperLeft
lr = ext.lowerRight
ur = ext.upperRight
arcpy.CreateFeatureclass_management(r"C:\Documents\ArcGIS\Default.gdb","extentoutput", "POLYGON")
outFC = r"C:\Documents\ArcGIS\Default.gdb\extentoutput"
array = arcpy.Array([ll, ul, ur, lr])
pg = arcpy.Polygon(array)
with arcpy.da.InsertCursor(outFC, ["SHAPE@"]) as cursor:
    cursor.insertRow([pg])
Edit:  If you want it as a polyline output FC, then be sure to add the starting point at the end to "close" the polyline as a bounding box:
ext = desc.extent
ll = ext.lowerLeft
ul = ext.upperLeft
lr = ext.lowerRight
ur = ext.upperRight
arcpy.CreateFeatureclass_management(r"C:\Documents\ArcGIS\Default.gdb","extentoutput", "POLYLINE")
array = arcpy.Array([ll, ul, ur, lr, ll])
pl = arcpy.Polyline(array)
    cursor.insertRow([pl])
