Counting in loop
1927
6
04-14-2021 05:57 AM
Mick
Good day everybody,
I am currently working with a feature class. I have a field with each cat that could be repeated around 100 or more times. However, I have 25 different cats.
My task is to count how many times each cat appears in the field. Currently, I have a total number 40000 when I use "numbermyList = len(myList)" after my loop and only one when I use it in the loop. When I use "numbermyList = len(cat)", it gives the total number only for the first cat but not working the other cats.(If i use inside or outside of the loop)
Could you please recommend to me how to use the loop to count the number of each cat in my field?
Certainly, I would like to use the received number in my next loop, so I will receive something like this: 1st cat = 4000(numbermyList = len(myList)), 2sd cat 5000 and so on (numbermyList = len(myList)).
JohannesLindner
cat_names = ["cat_1", "cat_2", "cat_3", "cat_25"]
cat_numbers = []
for name in cat_names:
    sql_query = "CatName = '{}'".format(name)
    cat_rows = [c for c in arcpy.da.SearchCursor("Cat_Layer", ["CatName"], sql_query)]
    cat_numbers.append(len(cat_rows))
for name, number in zip(cat_names, cat_numbers):
    print("{} appeared {} times in Cat_Layer.".format(name, number))
#cat_1 appeared 56 times in Cat_Layer.
#cat_25 appeared 572 times in Cat_Layer.
Have a great day!
Johannes
BlakeTerhune
You can use a default dictionary for this!
from collections import defaultdict
fakeCursor = ["one", "three", "two", "one", "one", "two", "five", "nine"]
counter = defaultdict(int)
for i in fakeCursor:
    counter[i] += 1
print counter
Output:
defaultdict(<type 'int'>, {'nine': 1, 'five': 1, 'three': 1, 'two': 2, 'one': 3})
jcarlson
Can you elaborate a bit on this? Do you mean you want the count of occurrences per cat, something like:
cat 1: 100
cat 2: 2500
etc...
I think part of the problem here is that the myList object is being redefined as an empty list for every iteration.
- Josh Carlson
Kendall County GIS
JoshuaBixby
MVP Esteemed Contributor
Since there is a bit of confusion over what you are trying to do within your loop, I suggest you step back from tools and solutions and explain a bit what your requirement is, i.e., just describe what you are trying to achieve overall.
JohannesLindner
cat_numbers = []
Have a great day!
Johannes
BlakeTerhune
Do you have other CatName values in Cat_Layer that aren't in cat_names? In other words, do you want to count all occurrences of every CatName value or only the ones you explicitly define?
JohannesLindner
Good question. In that case, you would run this before:
cat_names = [c[0] for c in arcpy.da.SearchCursor("Cat_Layer", ["CatName"])]
cat_names = list(set(cat_names))  # names of all cats in Cat_Layer
Have a great day!
Johannes
