count of maps in Arcpro project
2289
03-27-2022 03:36 PM
AmandaYoung_95
Hello, I have a arcpro project and inside the projects, i have 2 maps and and each map 3 layers. I want to print the number of maps and and number of layers within each maps. i have this so far and i am getting errors. any tips ?
import arcpy
aprx_path = "C:/.colorado.aprx"
aprx = arcpy.mp.ArcGISProject(aprx_path)
maps = aprx.listMaps()
for m in maps:
print(m.count)
jcarlson
The listMaps() method gives you a list. Simply call len(maps) to get the count. The code you have written is attempting to access a count property of each individual map and print it, but no such property exists, at least in my maps.
To get your layer counts per map, you just do the same thing, but with the output of the map's listLayers() method.
print(f'{len(aprx.listMaps())} maps in project.')
for m in aprx.listMaps():
    print(f'{len(m.listLayers())} layers in {m.name}')
- Josh Carlson
Kendall County GIS
DanPatterson
MVP Esteemed Contributor
The error message would help.
"C:/.colorado.aprx"
will fail, if that is the path since an aprx can't exist in the root directory nor begin with punctuation.
Also your formatting could use line numbers.
Code formatting ... the Community Version - Esri Community
... sort of retired...
jcarlson
Maybe that changed in a recent version?
Seems to work just fine. Not that it's a good idea, but it seems to be "legal".
- Josh Carlson
Kendall County GIS
DanPatterson
It will come back to haunt people at some point
works for some isn't a good idea
jcarlson
- Josh Carlson
Kendall County GIS
AmandaYoung_95
thank you!
