Count number of features inside polygon
6576
12
03-19-2020 01:30 PM
CCWeedcontrol
I need some help on my code to count the number of features inside a polygon. I have the following but after testing it, it doesn't seem to be correct. I am trying to figure out how many parcel lots are within the subdivision boundary. My test show after running the code that the "Stats" table has 9 Frequencies but in actually there is 10 parcels within the subdivision. I have tried "HAVE_THEIR_CENTER_IN" but all the results are 1.
import arcpy, os
mxd = arcpy.mapping.MapDocument("current")
df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0]
lyr = arcpy.mapping.ListLayers(mxd, "Taxlots")[0]
subs = arcpy.mapping.ListLayers(mxd, "SubsOutsideCities")[0]
#arcpy.MakeFeatureLayer_management(par, "parLyr")
arcpy.SpatialJoin_analysis(subs, lyr,"in_memory/points_SpatialJoin", "JOIN_ONE_TO_MANY", "KEEP_ALL", "", "CONTAINS")
arcpy.Statistics_analysis("points_SpatialJoin", "in_memory/stats", "Join_Count COUNT","OBJECTID")
RandyBurton
Perhaps something like:
countFC = 'polygons'  # feature containing outer polygons
countFld = ['ParcelCount', 'SHAPE@'] # ParcelCount is for count results, SHAPE@ is geometry of polygon
parcels = 'parcels' # parcels to be counted
with arcpy.da.UpdateCursor(countFC, countFld) as cursor: # cycle through outer polygon layer
    for row in cursor:
        arcpy.management.SelectLayerByLocation(parcels, "HAVE_THEIR_CENTER_IN", row[1], "", "NEW_SELECTION") # row[1] is SHAPE@
        row[0] = int(arcpy.GetCount_management(parcels)[0]) # row[0] to be updated with count
        cursor.updateRow(row) # update row‍‍‍‍‍‍‍‍‍‍
DanPatterson_Retired
Your shapes are all singlepart?  If not, run the Multipart to singlepart tool
CCWeedcontrol
Yes they are all singlepart.
many to one
one to one
one to many
switch the order of the join
which options did you try?
CCWeedcontrol
There is only two options for the spatialJoin_analysis, i am not sure what you mean by the other options.
JOIN_ONE_TO_ONE
JOIN_ONE_TO_MANY
JoeBorgione
Looks like you are using ArcMap to perform you analysis.  You might try to do it by hand, and then go to the geoprocessing results button; that'll tell what ArcMap just did for you and you can use that in your python coding.  I do that all the time with tools in Pro.
That should just about do it....
CCWeedcontrol
I have tried that and get the same results.
RandyBurton
    for row in cursor:
CCWeedcontrol
Randy I was able to get to work, thanks for the help.
import arcpy
with arcpy.da.UpdateCursor(subs, ["VxCount1", "Shape@"]) as cursor: # cycle through outer polygon layer
    for row in cursor:
        arcpy.management.SelectLayerByLocation(lyr, "HAVE_THEIR_CENTER_IN", row[1]) # row[1] is SHAPE@
        row[0] = int(arcpy.GetCount_management(lyr)[0]) # row[0] to be updated with count
save the result to disk, and open the table showing the OBJECTID for the join count.
click on every feature in turn and see if one of the features is actually 2 parts, or one feature is partially on top of the other
