Cost path values are smaller than cost surface
7082
12
04-12-2015 05:38 PM
BayuWidyasanyata
Hi All,
I'm recently do cost path calculations using cost distance and cost surface layer.
My cost surface values are between 1 to 19 (to simplify).
The result that made me confused was the final cost path surface really small, smaller than cost surface's.
Cost path values are around 0.00....
I use cost surface cell size of 30 m * 30 m.
And it calculated with model builder and python script which result the same values.
Is there anything I missed?
Thank you,
[bayu]
BayuWidyasanyata
Could you explain why it's in meters?
From what I understand, the cost path defines the "cost", real or might normalization cost. CMIIW.
DanPatterson_Retired
sorry, I assumed distance...units then....
BayuWidyasanyata
OK. Thank you!
