Correct Codeblock Python syntax for CalculateField
4747
11
01-09-2023 08:12 AM
MPach
 I'm using ArcMap 10.8.1 so this is Python 2.7.
  I'm trying to find the correct syntax to troubleshoot/debug this script that I'm working on. I was using the Python interpreter going line by line trying to resolve the issue and can't seem to figure out how to enter the codeblock into the interpreter. When I try to enter the codeblock as is I get a Syntax Error and I'm not skilled enough to know how to resolve it yet. It seems like the interpreter doesn't like the triple quotes for the codeblock. Any help is greatly appreciated!
expression = 'reclass(!{0}!,!{1}!,{2})'.format(lengthField, widthField, num)
codeblock = """ def reclass(lengthField,widthField,num):
                   if ((lengthField/num) >= (widthField)):
                       return 'True'
                   else:
                       return '' """
Brian_Wilson
Honored Contributor
AHhhh, now that makes sense. Either "True" or "" goes into the attribute as its new value. Okay.
Passing Python code uninterpreted into a function like that creeps me out. 🙂 But that's me. I bet you can pass the strings to "exec" to test. After all, Esri must be doing something like that.
Yes so you can do this, but it runs fine, no errors.
MPach
Also, I didn't want to return a 'False' string, I was just returning an empty string '', so there the field was left blank when it wasn't True. It just makes things visually easier when looking down the the column and I think it just looks cleaner that way.
