CopyRaster Environment Settings Not Being Applied
4218
08-30-2013 04:36 AM
PatrickDoody
I am making a call to arcpy.CopyRaster_management to convert some miscellaneous rasters into JPEG2000 *.jp2 files. Before making a call to this line, I want to set a few arcpy.env environment settings to be applied to the copy. Specifically, I would like to specify compression, pyramid, and tilesize.
My code looks like the following:
# Specifying the environment settings
arcpy.env.workspace = outWorkspace
arcpy.env.tileSize = "512 512"
arcpy.env.compression = "JPEG2000 75"
arcpy.env.pyramid = "NONE"
#Copying the raster
arcpy.CopyRaster_management(filepath,name + ".jp2","DEFAULTS","0","0","","ColormapToRGB","8_BIT_UNSIGNED")
The actual raster copies, and is correct. However, my arcpy.env settings are not applied. For example, my tileSize is not set to the specified 512x512, and the *.ovr overviews file is created even though I specified for pyramids to not be created ("NONE").
I am referencing the below document for CopyRaster_management: http://resources.arcgis.com/en/help/main/10.1/index.html#//001700000094000000
At the bottom of the document under "Environments" it lists the environment settings and the tileSize, compression, and pyramid options are listed, so I assume these should be getting applied.
Am I applying these environment settings incorrectly? How can I prevent overviews from being created, and my tileSize from being correctly applied? Any help is appreciated, thanks.
JamesCrandall
What is your output workspace/storage?
Here is the Raster Storage Matrix to see if those parameters are available for the storage type you are writing to:
http://resources.arcgis.com/en/help/main/10.1/index.html#//001w00000024000000
JakeSkinner
Esri Esteemed Contributor
Hi Patrick,
The tile size only affects rasters that are stored in TIFFs, file geodatabases, or an SDE geodatabase.  See the following link:
http://resources.arcgis.com/en/help/main/10.2/index.html#//001w00000021000000
As for the pyramids not being built, I found the following bug, NIM070791:
The geoprocessing tool, Copy Raster, builds pyramids even if the build  pyramids check box in the 'Environment Variable' is unchecked. This  happens only when the output is a file raster (TIFF) and when setting  any of the parameters like 'Ignore background value', 'colormapToRGB' or  'convert 1 bit data to 8 bit data.'
This appears to occur for JP2 as well as TIFF files.  When not specifying the 'Colormap to RGB' option, the OVR file is not created.
DorothyMortenson
I'm having a similar issue. I cannot seem to get the compression environment to work.
I have tried it in a python script with
arcpy.env.compression = "JPG 50"
I get no compression
(original is a tif)
I also tried using ArcTools and change the Raster Storage parameters and get the same thing. No compression.
Did anyone ever figure this out?
Dorothy
PaulCone
Same here -- my script has
arcpy.env.compression = "JPEG2000"
but I end up with LZ77 anyway, which results in a dataset that is too huge.  If I can't script this then I have to run it by hand to get the result I need.
Paul
Paul Cone
Corporate GIS
City of Portland, Bureau of Technology Services
[email protected]
JeniferCochran1
Is this still an issue in ArcMap 10.4.1?
