copyfield based on Cxxxx
3157
7
06-25-2013 03:10 PM
ElaineKuo
System: Windows Vista and ArcGIS 9.3
Hello,
I have 100 shapefiles called geocXXXX.shp (geoc0782, geoc9838, and geoc6728 etc)
In each shapefile, there is a field call CXXXX (C0782, C9838, and C6728 etc).
The field property is string, length =6.
Now I would like to make a new field call CXXXXD (C0782D, C9838D, and C6728D etc).
The field property is long integer, length =9.
Please kindly advise how to modify the follow code and thank you.
##Script Name: Copy field ##Description: Copy field using CXXXX ##Created By: Elaine Kuo ##Date: 06/25/2013   #Import standard library modules import arcgisscripting import os  #Create the Geoprocessor object gp = arcgisscripting.create(9.3)  #Set the input workspace #GP.workspace = sys.argv[1] #Set the workspace. gp.Workspace= "H:/temp_D/test"  #Set the output workspace #outWorkspace = sys.argv[2] #Set the workspace. List all of the feature classes in the dataset outWorkspace= "H:/temp_D"  #Get a list of the featureclasses in the input folder fcs = gp.ListFeatureClasses()  # Loop through every item in the list that was just generated for fc in fcs:      # Break out the name, no path or extension, using the describe object.     desc = gp.describe(fc)     featureName = desc.name      #Validate the new feature class name for the output workspace.     OutFeatureClass = outWorkspace + os.sep + gp.ValidateTableName(fc,outWorkspace)      #get file name     fcName, fcExt = os.path.splitext(fc)          #   Get a list of the fields in the featureclass     fields = gp.listFields(fc, "C*", "String")      # replace the strings you want to     fcName = fcName.replace("D","")     fcName = fcName + fcExt     fcName = outWorkspace + os.sep + fcName          #get file name     fcName, fcExt = os.path.splitext(fc)      fieldName = fcName + "D"  #build field name      #Add field to each SHP     gp.AddField_management(fc, fieldName, "LONG", 9, 3)
RDHarles
I see this snippet in the code, but don't know what it is used for as it looks like you get the name from the os.path.split section:
I don't see anywhere else that you are using the desc or featureName variables.  If so, the describe is fairly heavy operation, especially within a for loop.
If it really isn't needed, would probably decrease your run time substatially if removed.
R_
Nor do these lines look necessary:
#Validate the new feature class name for the output workspace.     OutFeatureClass = outWorkspace + os.sep + gp.ValidateTableName(fc,outWorkspace)      #get file name     fcName, fcExt = os.path.splitext(fc)         #Get a list of the fields in the featureclass     fields = gp.listFields(fc, "C*", "String")
RDHarles
If the code in the shapefile name is the same as the code you want in your new field name, simply do this:
import arcgisscripting, os
#Loop through the fc's
for fc in fcs:
    # Get the numeric code from the shapefile name
    numCode = fc[4:8]
    # Build the field name
    fieldName = "C"+numCode+"D"
    print "Updating file "+fc+" with fieldname "+fieldName+"..."
ElaineKuo
Thank you.
The code worked wonderfully.
The complete code (create a field (CXXXX) and copy a number to it)
is
##Date: 06/25/2013
import os
#Set the workspace.
for fc in fcs:
    #get file name
    numCode = fc[4:8]
    gp.AddField_management(fc, fieldName, "LONG", 9)
     # Make temporary featureclasses
    gp.MakeFeatureLayer(fc,"lyr")
    fields = gp.ListFields("lyr", "C*", "String")
    for field in fields:
        gp.toolbox = "Data Management"
        # Select records to be copied (C*, i.e. C7658)
        query = "\"%s\" = 'R'" % field.Name
        gp.SelectLayerByAttribute("lyr", "ADD_TO_SELECTION", query)
        # copy values in existing fields to the new field
        gp.CalculateField("lyr", fieldName, "1", "PYTHON_9.3")
gp.AddMessage(gp.GetMessages())
print gp.GetMessages()
RDHarles
Glad I could help.
R.D.
RhettZufelt
MVP Notable Contributor
R_
RDHarles
R_
RhettZufelt
Didn't even recognize that.  Guess I really wasn't trying to pick apart the code, just that I have been "bitten" by describe statements within a loop before, so that really stood out to me.
R_
RDHarles
R_
Good to know about the Describe, didn't know it was so "computer intensive".
