copy_management associated_data in loop to rename only renames the first
3045
01-29-2019 07:10 AM
DavidPersson
I'm using the ArcGIS Pro Python console (we are using ArcGIS Desktop 10.5 mostly but its copy_management doesn't have the associated_data parameter) in order to try to do the following:
Copy all feature classes under a specific data set in an enterprise geodatabase to a new / existing data set with a specific name in the same database and in the process rename the feature classes using a suffix.
This is the current python code:
suffix = "_imahappysuffix"
in_data =  "C:/tempo/pyth/data_owner_connection.sde/db_test.dataowner.mexico"
out_data = "C:/tempo/pyth/data_owner_connection.sde/db_test.dataowner.newdataset"
arcpy.env.workspace = r'C:\tempo\pyth\data_owner_connection.sde'
dss = arcpy.ListDatasets("db_test.dataowner.mexico","Feature")
for ds in dss:
    for fc in arcpy.ListFeatureClasses(feature_dataset=ds):
        arcpy.Copy_management(in_data, out_data, associated_data=fc+" FeatureClass "+fc+suffix)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
This executes and creates a new dataset named newdataset (if it didn't exist) and then creates a copy of the first feature class with the intended suffix. The second and third feature classes in the origin data set however are only given a _1 suffix in the target data set, how come?
I think something might be wrong with how I use associated_data but I haven't figured out what yet.
In the target data set I'm getting:
db_test.dataowner.mexico_dots_imahappysuffix
db_test.dataowner.mexico_realms_1
db_test.dataowner.mexico_rivers_1
Thanks for reading : )
Tags (1)
DanPatterson_Retired
Copy Features—Data Management toolbox | ArcGIS Desktop if you are just copying featureclasses
Copy—Data Management toolbox | ArcGIS Desktop  has a lot more fluff associated with it and seems to be targeted for particular situations
Is it your intention to use the latter instead of the former?
JoshuaBixby
MVP Esteemed Contributor
I haven't worked with the newish associated_data parameter yet, but according to Copy—Data Management toolbox | ArcGIS Desktop you appear to be running into some form of expected behavior:
The from_name and to_name column names will be identical if the to_name is not already used in out_data. If a name already exists in the out_data, a unique to_name will be created by appending an underscore plus a number, _2.
In your case it is appending _1 instead of _2
DavidPersson
Thanks, that's a good point; possibly it's copying all origin feature classes thrice, hah, loop-logic-failure if so. Checking..
DavidPersson
My intention is to get all feature classes in a specific data set copied under new names (suffix) into another dataset; seems Copy Features can do just that too, after CreateFeatureDataset. Got it working now with a .gdb-source and target, will try .sde-target tomorrow. Cheers for the advice!  : )
Edit. Just wanted to say that CopyFeatures_management appears to work for the intended job. No potential issues with selections either as enterprise geodatabase feature classes -> enterprise geodatabase feature classes. Thanks again! (if anyone is interested in the rough little script I made I'll attach it here, am not certain yet how the forum usually goes )
