Copy Features Error 000210
4008
6
01-20-2021 05:13 AM
JacobConshick
I am trying to copy my feature but for some reason I keep getting Error 000210. I am using Arcpro and I did the fixes online but I cannot get it to work.
Tags (3)
DavidPike
MVP Notable Contributor
Can you give more context/information on what you're doing, what tools you're using to do it, and the full error message?
This is in the python area, is this a script which is failing or just a tool? If a script, can you share the script?
JacobConshick
I am trying to copy a shapefile before I perform my analysis so I have a backup. This worked Thursday last week with no issue but now it is not.
This is code subset
input shapefile: feature = r"J:\1086\210\GIS\ROW_140\Data\OLIVER\Refined\Acushnet_Oliver_Parcels_15.shp"
output shapefile: featureCopy = r"J:\1086\210\GIS\ROW_140\Data\Draft\Draft_Acushnet_Parcels.shp"
tool used: arcpy.CopyFeatures_management(feature, featureCopy)
Error:
ERROR 000210: Cannot create output J:\1086\210\GIS\ROW_140\Data\Draft\Draft_Acushnet_Parcels.shp
Failed to execute (CopyFeatures).
DanPatterson
MVP Esteemed Contributor
JacobConshick
I can see how that would work when using a geodatabase. But I am not sure if this would apply for shapefiles. My input and output are two different shapefiles going to two different locations.
DanPatterson
then the tool inputs or you python code needs to be looked at
... sort of retired...
DanPatterson
print(p)
J86ˆ\GIS\ROW_140\Data\Draft\Draft_Acushnet_Parcels.shp
the old path beginning with numbers issue
raw encoding
 p = r"J:\1086\210\GIS\ROW_140\Data\Draft\Draft_Acushnet_Parcels.shp"
print(p)
