Convert x,y to lat, long
10243
14
07-22-2015 10:09 AM
CCWeedcontrol
I currently have a code that creates a point with a mouse click and works great, but i need the x,y to be calculated to lat and long. The current codes does that but it is slow and i use updatecursor. I would like to like to do the conversion when the ptGeometry, basically store it in the point when it gets created because with the current code it takes about 30 secs. I have tried to makefeaturelayer with the ptGeometry but and insert the lat long fields and then use the to update the point but i get nothing. so i need some help on how i can do this with the current code.
#import modules
import arcpy
tool box parameters
point param = feature set
targetpoint = featurelayer
parcel = featurelayer
arcpy.env.qualifiedFieldNames = False
point = arcpy.GetParameterAsText(0)  #point boolen
targetpoint = "CCAP" #target point feature class
parcel = "parcels"  #target feature class
parcel_lyr = 'parcel_lyr'
for prow in arcpy.da.SearchCursor(point,'SHAPE@XY'):
    x,y = prow[0]
del prow
point1 = arcpy.Point(x, y)
ptGeometry = arcpy.PointGeometry(point1)
CC_list = []
with arcpy.da.SearchCursor(targetpoint, ["AddressID"]) as cursor:
    for row in cursor:
        try:
            if "CC" in row[0]:
                CC_list.append(int(row[0].strip("CC")))
        except TypeError:
            pass
del cursor
CC_list.sort()
AddressID = CC_list[-1] + 1
AddressID = 'CC' + str(AddressID)
arcpy.MakeFeatureLayer_management(parcel,parcel_lyr)
arcpy.SelectLayerByLocation_management(parcel_lyr,"INTERSECT",ptGeometry)
fldList = ['ACCOUNT','OwnerName','SiteAddres','SiteNum','siteNumSfx','Predir','SiteStreet', 'StreetType', 'Postdir', 'SiteCity', 'SiteZip']
fldDict ={}
#Check that we only have one parcel and get the attributes from it
if int(arcpy.GetCount_management(parcel_lyr).getOutput(0))==1:
    for parrow in arcpy.da.SearchCursor(parcel_lyr,fldList):
        for w in range(len(fldList)):
            fldDict[fldList]=parrow
    del parrow
    targetFields = ['ACCOUNT', 'OwnerName', 'SiteAddres', 'SiteNum', 'siteNumSfx', 'Predir', 'Postdir', 'SiteCity', 'SiteZip',
                    'SiteState', 'FacltyType', 'StructType', 'GIS_STEW', 'UpdateBy', 'Verified', 'Status', 'StructCat', 'APA_CODE',
                    'AddressID', 'POINT_X', 'POINT_Y', 'StreetName','SHAPE@XY']
    tprows = arcpy.da.InsertCursor(targetpoint, targetFields)
    row = []
    #Attributes from parcels
    row.append(fldDict['ACCOUNT'])
    row.append(fldDict['OwnerName'])
    row.append(fldDict['SiteAddres'])
    row.append(fldDict['SiteNum'])
    row.append(fldDict['siteNumSfx'])
    row.append(fldDict['Predir'])
    row.append(fldDict['Postdir'])
    row.append(fldDict['SiteCity'])
    row.append(fldDict['SiteZip'])
    #Preset attributes
    row.append('ID')
    row.append('Single Family Home')
    row.append('Primary, Private')
    row.append('CanyonCo')
    row.append('TA')
    row.append("Yes, GRM, TA")
    row.append('Active')
    row.append('Residential')
    row.append('1110')
    row.append(AddressID)
    row.append(x)
    row.append(y)
    row.append(fldDict['SiteStreet'] + " " + fldDict['StreetType'])
    row.append(point1)
    tprows.insertRow(row)
arcpy.RefreshActiveView()
del tprows
#convert x,y to lat & long
latLonRef = "Coordinate Systems\Geographic Coordinate Systems\North America\NAD 1983.prj"
featureClasses = arcpy.GetParameterAsText(0)
featureClassesList = featureClasses.split(";")
for featureClass in featureClassesList:
    rows = arcpy.UpdateCursor(targetpoint, "", latLonRef)
    for row in rows:
      feat = row.getValue("shape")
      cent = feat.centroid
    # To get the polygon area: cent = feat.area
      row.POINT_X = cent.Y
      row.POINT_Y = cent.X
      rows.updateRow(row)
      #arcpy.AddMessage(str(lat) + ", " + str(lon))
else:
    arcpy.AddMessage("Number of parcels selected incorrect for this process")
Message was edited by: 2CDSD 2C
DarrenWiens2
That's because you're appending the variables 'x' and 'y' that you calculated at the beginning. If you want 'x' and 'y' to hold the lat/long values, you need to assign them as such.
x = pointA.centroid.X
y = pointA.centroid.Y
...but now I'm not even sure what the 'point' feature set is supposed to be doing. Anyhow, I think your code has undergone so many revisions that you should really sit down and figure out what all your variables are doing.
DarrenWiens2
See this thread for how you can use arcpy.PointGeometry.projectAs() to change coordinate systems at the individual point level.
CCWeedcontrol
i have tried the follwoing but getting an error.
  File "C:\GIS\Python\UpdateAddressPoints\CreatePointUdateAttributesTest6.py", line 29, in <module>
    pointA = point_utm.projectAs(arcpy.SpatialReference(115702))
  File "c:\program files (x86)\arcgis\desktop10.2\arcpy\arcpy\arcobjects\mixins.py", line 927, in __init__
    self._arc_object.createFromFile(item)
RuntimeError: ERROR 999999: Error executing function.
the input is not a geographic or projected coordinate system
#import modules
import arcpy
tool box parameters
targetpoint = "CCAP2" #target point feature class
    x,y = prow[0]
del prow
with arcpy.da.UpdateCursor(point,["POINT_X","POINT_Y"]) as cursor:
    for row in cursor:
        point_utm = arcpy.PointGeometry(arcpy.Point(row[0],row[1]),arcpy.SpatialReference(103269))
        row[0]= pointA.centroid.X
        row[1]= pointA.centroid.Y
        cursor.updateRow(row)
CC_list = []
    for row in cursor:
        try:
            if "CC" in row[0]:
        except TypeError:
            pass
del cursor
CC_list.sort()
fldDict ={}
    del parrow
    row = []
    #Preset attributes
    row.append('ID')
    row.append('TA')
    row.append('1110')
    row.append(x)
    row.append(y)
    row.append(point1)
del tprows
DanPatterson_Retired
115702   the input is not a geographic or projected coordinate system
Given the number and the error, is it correct or what is it supposed to be
CCWeedcontrol
it's going from projected coordinates to geographic coordinates.
DarrenWiens2
Try 4269 (the NAD83 geographic coordinate system) rather than 115702 (the NAD83 spheroid).
For reference:
Projected Coordinate Systems
CCWeedcontrol
I made the change from 115702 to 4269 the code ran but the POINT_X and POINT_Y did not get converted, no error.
    for row in cursor:
        pointA = point_utm.projectAs(arcpy.SpatialReference(4269))
DarrenWiens2
Did you reload the table cache? If you have the table open, it won't automatically update until you reload it.
Anyhow, this code updates my table with lat/long, from UTM.
>>> with arcpy.da.UpdateCursor("coord_test",["ET_X","ET_Y"]) as cursor:
        for row in cursor:
            point_utm = arcpy.PointGeometry(arcpy.Point(row[0],row[1]),arcpy.SpatialReference(26910))
WesMiller
point is a feature set and does not have fields "Point_X" or "Point_Y" try running Darren Wiens​ code on the targetpoint
CCWeedcontrol
if i run it against the target point it take 1 min. 7 secs, with no error. The point is created but the x,y are not lat long.
