Convert VB Code to Python
3819
09-14-2012 05:41 AM
MarkFaulkner
I have some VB code that I used in 9.3.1 to flip selected polyline orientation. It no longer works in 10.1, is there a Python equivalent I can use to calculate on the [Shape] field?
Pre-logic Script Code:
Dim pCurve As ICurve
If (Not IsNull([Shape])) Then
  Set pCurve = [Shape]
  If (Not pCurve.IsEmpty) Then
    pCurve.ReverseOrientation
  End If
Shape=
pCurve
Mark
JakeSkinner
Esri Esteemed Contributor
Hi Mark,
You can use the Flip Line tool to do this.  This tool will also honor selected features.
