Convert Labels To Annotation
5384
8
12-13-2016 06:31 AM
ChrisHolmes
Hello everyone,
Wondering if there is a way to complete the following using arcpy.
Any insights appreciated. My searches so far haven't turned much up.
Chris
JayantaPoddar
JayantaPoddar
Did you check Tiled Labels to Annotation?
Think Location
ChrisHolmes
Thanks. I will look into that!
JamesCarpenter2
Did this work for you Chris?
ChrisHolmes
Thanks for the reminder James. Yes, I’m just ironing out a few bugs and will then post the solution.
JamesCarpenter3
Great. Thanks! This is exactly what I am trying to do in Data Driven pages. A script will save tons of clicks.
ChrisHolmes
Here's the solution I have to date. It is in the context of a model at this point. I plan to at some point move it into a single script tool.
Script for CreatePolygonE (found the base code for this on geonet from Jake Skinner - Thanks Jake):
import arcpy
locno = arcpy.GetParameterAsText(0)
year = locno[3:7]
arcpy.AddMessage('locno: ' + locno)
workspace = "O:/plan/luam/1p2007/" + year + "/" + locno + "/data_for_item.gdb" #|data"
arcpy.env.workspace = workspace
mxd = "O:/plan/luam/1p2007/" + year + "/" + locno + "/" + locno + "-existing_proposed.mxd"
mxd = arcpy.mapping.MapDocument(mxd)
dataframe = arcpy.mapping.ListDataFrames(mxd, "*")[0]
frameExtent = dataframe.extent
XMAX = frameExtent.XMax
XMIN = frameExtent.XMin
YMAX = frameExtent.YMax
YMIN = frameExtent.YMin
pnt1 = arcpy.Point(XMIN, YMIN)
pnt2 = arcpy.Point(XMIN, YMAX)
pnt3 = arcpy.Point(XMAX, YMAX)
pnt4 = arcpy.Point(XMAX, YMIN)
array = arcpy.Array()
array.add(pnt1)
array.add(pnt2)
array.add(pnt3)
array.add(pnt4)
array.add(pnt1)
polygon = arcpy.Polygon(array)
arcpy.CopyFeatures_management(polygon, "Polygon_Extent")
result = True
arcpy.SetParameterAsText(1, result)
Script for CreateAnnotation:
import arcpy
year = locno[3:7]
Polygon_Extent = "O:/plan/luam/1p2007/" + year + "/" + locno + "/data_for_item.gdb/Polygon_Extent"
outGdb = "O:/plan/luam/1p2007/" + year + "/" + locno + "/data_for_item.gdb"
GroupAnno = "GroupAnno"
# Process: Tiled Labels To Annotation
arcpy.TiledLabelsToAnnotation_cartography(mxd, "Layers", Polygon_Extent, outGdb,
        GroupAnno, "Anno", "4000", "", "", "", "", "STANDARD", "GENERATE_UNPLACED_ANNOTATION")
result = True
ChrisHolmes
So, while I was able to get this working and save the annotation to a file geodatabase. The "Convert Labels to Annotation" form in the manual arcMap process to give you the ability to save the annotation in the existing mxd file. I was not able to find a way to accomplish that with arcpy. Is that not possible?
Thanks all!
BrittneyWhite1
From this GeoNet post, Annotation classes not visible after adding an annotation layer, it looks like you can  use  MakeFeatureLayer_management to create a layer and then add the layer using mapping.AddLayer.
