Convert Decimals Degrees to Floating Point UTMS.
2150
07-11-2019 10:32 AM
BenjaminZandarski
I have coordinates in decimal degrees in one table. I need to convert them to UTMs in another table. I can use
arcpy.ConvertCoordinateNoatation_management(input, output, geoLat, geoLong, "DD_2", "UTM ZONES").
This gives me the UTMS and I can index them to place them in a northing and easting column. The problem is the other table that I need to put these in has UTM coordinates as a floating point number. Is there a simple way to get the UTMs as a floating point number from the Decimal Degree Coordinates?
JoeBorgione
Once you get the UTM coordinates, how are you then updating the other table?  Once you have a 'number' you can cast it to what ever type you need.  See https://www.tutorialspoint.com/python/python_numbers
Psuedo code:
NorthingInNewTable = float(NorthingUTM)
That should just about do it....
BenjaminZandarski
Thanks for the help. The problem is I have a set of coordinates in decimal degrees when I run the ConvertCoordinateNoatation tool it returns the UTMs as a string  (e.g 13N6046424148283). I need this to be in 2 columns. (e.g coordinateX = 604642.396 coordinateY =4148283.7975) for every point in my table. I can get the UTMs by parsing the string that is returned by  the ConvertCoordinateNoatation tool but I cannot get the precision as this is not returned by the ConvertCoordinateNoatation tool. Is there another tool or better way to do this in Python.
JoeBorgione
Nothing that I can think of off hand... What if... (and this might be quite the work around):
Take your DD table and add it as an XY event Table.
Save that as feature class
Add two float attributes, UTM_X , UTM_Y
Use the Calculate Geometry calculator accordingly
DanPatterson_Retired
Add Geometry Attributes—Data Management toolbox | ArcGIS Desktop
You just need to specify the coordinate system that you want
