Connect to MSSQL Server with Python using SQLAlChemy
21250
06-22-2023 07:15 AM
ChallagundlaSindhuraITS
I have installed SQLAlchemy 2.0.16 on my machine. I am trying to connect to sql server database using below code:
from sqlalchemy import text , create_engine
Server = ''
Database = ''
Driver = ''
Database_Con = f'mssql://@{Server}/{Database}?driver={Driver}'
#Create the engine to connect to the database
engine=create_engine(Database_Con)
con = engine.connect()
Throws ModuleNotFoundError: No module named 'pyodbc'
If I do a pip install pyodc it works. But my team doesnt want me to install pyodc and want to try to connect to SQLengine. Please let me know any alternatives. Thank You
EarlMedina
Seems like your problem is related to create_engine. pyodbc is used as the default DBAPI. You may also use pymssql. You can learn more about this here: https://docs.sqlalchemy.org/en/20/core/engines.html
I would explain to your team that's just how things work. You need some kind of DBAPI and here you have two options.
