Confused with this error "list indices must be integers"
7136
21
07-31-2012 08:34 AM
JonPedder
Morning, I'm receiving this error when running a For loop "list indices must be integers". Could this be because my list is of stype string?
Here's the code. First I write values to list lMembers
rowMembers = arcpy.SearchCursor(fc6,qTeam)     lMembers = []     for z in rowMembers:         mName = z.getValue("Name")         lMembers.append(mName)
Then I later try to write these values. Currently I'm just displaying them for debugging.
    for i in lMembers:         wMembers = lMembers         arcpy.AddMessage(lMembers)         arcpy.AddMessage(wMembers)
Not quite sure what I'm doing incorrectly
thanks in advance for you help
Jon
MathewCoyle
Honored Contributor
Remove the second string index reference to the name_field variable in your output line.
Should look like this.
txt.write("<</T({0})/V({1})>>\n".format(name_field,item))
JonPedder
That did get it!
Again I really appreciate your time helping me with this.
If you do get a chance to explain the loop in the next few days that'd be great.
Jon
