Conditionally deleting records
7623
15
04-02-2019 10:17 AM
PrestonEllison
Im trying to come up with a way to conditionally delete some records in a table. For instance, i have variably shaped polygons that when spatially joined with a point feature class tend to result in excess points on the larger polygons. I would like to set up a definition query to select and eventually delete every other or even every 2 out of 3 rows IF (and only if) there are, say more than 10 occurrences of that record. Im trying to implement this in arcmap via a python/sql query. Im sure there is way to do this in the output file (.csv) but I would like to maintain the integrity of the data in arcmap prior to exporting it.
Any help on how to go about doing this?
JoshuaBixby
MVP Esteemed Contributor
If you type the following after the code runs, what do you get:
print(oids)
I tested the code on some sample data on my machine before posting it, so I think the logic and code are sound.  Can you post either a subset and/or sanitized set of data here for me to test on?
PrestonEllison
Absolutely, whats the best route to get you a sample data set?
When i run the print, I get the following....
JoshuaBixby
Just looking at your screenshot, you left off the last line, the one that actually selects the records:
fl.setSelectionSet("NEW_SELECTION", oids)
PrestonEllison
Yikes, how did i miss that.
It works! This is perfect. Im assuming i could change the frequency of the selection by adjusting line 6 "group size"
JoshuaBixby
Yes, the group_size variable sets how many photo points you want per Account_Nu, roughly.  If you only have 3 points and the group size is 6, it will just select all 3.  The trick that took a bit of thought was how to get staggered points along the photo traversing path.  Grabbing the first or last x number of photos is easy, but I figured you don't want just 4 photos at the start of the property if there are 50 photos along the perimeter of the property.
PrestonEllison
Exactly. The idea was to get a representative view of the entire property vs just a cluster of points from roughly the same location.The way this is set up is extremely helpful and i cant thank you enough.
cheers
