Conditional replace function in Field Calculator
3274
06-20-2012 05:11 AM
BenjaminYoung
I'm trying to write an expression that will allow me to change the text of a string field based on it's values.
Here's what I have so far.
Dim output as String
IF [DUPLICATE] = "0"
THEN
output = replace( [DUPLICATE], "0", "CATEGORY 1")
end if
IF [DUPLICATE] = "1"
THEN
output = replace( [DUPLICATE], "1", "CATEGORY 2")
end if
IF [DUPLICATE] = "2"
THEN
output = replace( [DUPLICATE], "2", "CATEGORY 3")
end
Any help would be appreciated.
JimCousins
A single "=" is an assignment. In order to do a comparison, use "==" a double equal sign. You could also nest these individual if statements with:
if [DUPLICATE] == "0":
elif [DUPLICATE] == "1":
BenjaminYoung
Thanks but still not working. Is it something with the
Tried that line by itself and returned an error.
JasonScheirer
Esri Alum
In the Field Calc, need to do !DUPLICATE! and not [DUPLICATE] in Python.
JimCousins
Also be mindful of indentation. My earlier post didn't show correct indentation after the if statement. Apologies for that.
DarrenWiens2
Firstly, you need to decide if you want to use VBScript or Python. You started with almost functional VBScript and have been slowly drifting into functional Python.
PYTHON:
In the expression box:
func(!DUPLICATE!)
Then, in the codeblock:
def func(dup):
    if dup == "0":
        return "CATEGORY 1"
    elif dup == "1":
        return "CATEGORY 2"
VBSCRIPT:
result
Codeblock:
if [DUPLICATE] = 0 then
  result = "CATEGORY 1"
elseif [DUPLICATE] = 1 then
  result = "CATEGORY 2"
else
  result = [DUPLICATE]
end if
