Concatenate Julian Day + Year to get Date
7787
10
07-01-2019 12:59 PM
AurelieShapiro
I am looking for an Arcade or python code (for use in Calculate Value in ModelBuilder) to concatenate two fields of an attribute table:
-Julian Day (1-365)
-Year (YYYY)
to calculate a field with a date (mm/dd/yyyy)
I tried Convert time field and it just made all my dates January 1 2001.
Can anyone help?
Thank you!!
XanderBakker
Esri Esteemed Contributor
Hi Aurelie Shapiro ,
This would be the way you could use Arcade to get the date:
// input data from feature attributes
var year_value = $feature.Def_Year;
var julian_day = $feature.grid_code;
var year_date = Date(year_value, 0, 1);  // create date using first day of year
var final_date = DateAdd(year_date, julian_day, 'days');  // add the julian days
return final_date;‍‍‍‍‍‍‍
RandyBurton
You might try something like:
from datetime import datetime
dt = datetime.strptime('6/1/2019', '%m/%d/%Y')
tt = dt.timetuple()
print "{}-{}".format(tt.tm_yday, tt.tm_year)
# prints:  152-2019‍‍‍‍‍‍‍‍‍‍‍‍
See also: Extract day of year and Julian day from a string date
AurelieShapiro
Thanks! Timetuple seems to be getting there.
But my two field are Julian Date of the year (dd) and year (yyyy). How do I do the opposite of what you propose? (sorry I don’t know python, I am looking for a code to integrate my two variables: dd & yyyy = dd/mm/yyyy
Thanks!
-a
Von: Randy Burton <[email protected]>
Gesendet: Montag, 1. Juli 2019 22:43
An: Shapiro, Aurelie <[email protected]>
Betreff: Re: - Re: Concatenate Julian Day + Year to get Date
GeoNet, The Esri Community | GIS and Geospatial Professional Community <https://community.esri.com/?et=watches.email.thread>
reply from Randy Burton<https://community.esri.com/people/rvburton?et=watches.email.thread> in Python - View the full discussion<https://community.esri.com/message/861794-re-concatenate-julian-day-year-to-get-date?commentID=861794&et=watches.email.thread#comment-861794>
XanderBakker
Hi aurelies
You could probably use something like this:
import datetime
jul_day = 60  # will point to your field value for Julian Day
year = 2016  # will point to your field value for Year
print datetime.datetime.strptime('{}-{}'.format(year, jul_day), '%Y-%j').date()
AurelieShapiro
do you know how to do this in Calculate field? It runs but outputs a null date...
Date_Def is my date field to output
Def_Year is the year
grid_code is the julian date
XanderBakker
Hi aurelies
Can you share a screenshot of your data (the two fields involved?)
XanderBakker
AurelieShapiro
it worked! genius!!!
XanderBakker
Hi aurelies ,
I'm glad it works now. Indeed in some case it would have required casting the text to a value. Which solution did you finally use? Python or Arcade?
Can you mark the post with the correct answer so that others can find the answer more easily?
vdsri55
Can you please share same code in pyspak.
