Compression issue
1465
07-05-2017 07:29 AM
IreneEgbulefu1
JakeSkinner
Esri Esteemed Contributor
Hi Irene,
You can try the following scrip tool to see if this works:
https://community.esri.com/docs/DOC-9914
If it also fails, then it is most likely something wrong with the geodatabase.  If it succeeds, then it could be a syntax/script error.
