Comparing Time in a Python List/SearchCursor
4103
09-09-2015 09:11 AM
MatthewRusso
Hi All,
I have created a script that does some data checks and I am down to my last check. Where I am stuck at is comparing time Values between rows in a Search Cursor.
for example I will have several tables that have 2-10 values in them.
My code looks something like this:
table = 'b3514str133'
field = "INP_DATE"
tempList = []
with arcpy.da.SearchCursor(table, field) as cursor:
     for row in cursor:
          tempList.append(row)
# My Templist now looks like this : [(datetime.datetime(2015, 4, 1, 14, 22, 4),),
                                     (datetime.datetime(2015, 4, 1, 14, 22, 10),),
                                     (datetime.datetime(2015, 4, 1, 14, 22, 15),),
                                     (datetime.datetime(2015, 4, 1, 14, 22, 20),),
                                     (datetime.datetime(2015, 4, 1, 14, 22, 37),)]
          for item in tempList:
               if any of the items are within 1 hour of each other:
                    print row
My first question is: Is this the easiest way to do this?
My Second question is: Should I be using a list to do this or can i compare each row by all the other rows?
My third question is: What if statement could i used to compare each row within 1 hour of each other?
My checks go through about 5 different levels of verification so my mind is currently blown!!!!
Any help would be great thanks!
-Matt
BruceHarold
Esri Frequent Contributor
Hi
You have arcpy.time.EsriTimeDelta at your disposal, make deltas for each datetime in your list and test for < and >.
Regards
JoshuaBixby
MVP Esteemed Contributor
Since your comparison interval isn't weeks, months, or greater, I don't think EsriTimeDelta is necessary in this case, but you could go that route if the interval may get that large.
If you simply want to compare a row's datetime with the previous row's datetime, something like this should work:
date_field = "INP_DATE"
interval = datetime.time(1)  #specify 1-hour interval
with arcpy.da.SearchCursor(table, date_field) as cursor:
    previous, = next(cursor)
    for dt, in cursor:
        if dt - previous <= interval:
            print row
        previous = dt
If you want to compare a row's datetime with all previous rows' datetimes, or all rows' datetimes, then the situation gets more involve
