Comparing multiple fields to each other within one feature class using Python?
2323
6
04-11-2018 07:42 AM
DeidreA
So I have a feature class of 5 fields that I'm looking at. I'm looking to compare 4 fields to 2 other fields. Essentially, if any of the first 4 fields match to the other 2 fields then I want to return a "YES" in a new field. If none of the 4 fields match the 2 fields, then I want to return a NO. I started typing this out in the field calculator, but I'm unsure if this is the most efficient method.
I'm a beginner at python, so here is my code below:
def TextValue(MATCH):
  if !JURIS! or !MGMT1! or !MGMT2! or !MGMT3! == !EDC_MGMT! or !EDC_JURIS!:
    return = "YES"
  elif:
    return = "NO"‍‍‍‍‍
Am I going about this the right way? Let me know if my question should be clarified.
DanPatterson_Retired
a = [1, 2, 3, 4]
b = [2, 4]
sum([True for i in a if i in b])
substitute the numbers for your field names.  If the sum is > 0, then it is true, otherwise false
DeidreA
The only thing is that they're text fields. Unless I'm misunderstanding you? I'm unsure how this would still apply. Also, can I still do this in the field calculator?
Thank you so much for your help!
[0, 1][sum([True for i in [!a!, !b!, !c!, !d!] if i in [!e!, !f!])]
would be a field calculator expression, python parser, a to f are field names
RandyBurton
If there is more than 1 match, you will get an index error.  Also a bracket is missing.
[0, 1][sum([True for i in [!a!, !b!, !c!, !d!] if i in [!e!, !f!]])]
But it is a nice way to make multiple comparisons.
a = 'a'
b = 'b'
c = 'c'
d = 'd'
e = 'd'
f = 'b'
print sum([True for i in [a, b, c, d] if i in [e, f]])
print "yes" if sum([True for i in [a, b, c, d] if i in [e, f]]) else "no"
# results
yes
a, b, c, d = 'abcd'
e, f = 'ab'
[0, 1][max([True for i in [a, b, c, d] if i in [e, f]])]
was using the phone... max is the correct, rather than sum, since it will either be 0 or 1, so even a single 1 will trigger
Again, substitute the letters for your field names
JoshuaBixby
MVP Esteemed Contributor
Try this in the code block:
def TextValue(juris, mgmt1, mgmt2, mgmt3, edc_mgmt, edc_juris):
    s4 = set([juris, mgmt1, mgmt2, mgmt3])
    s2 = set([edc_mgmt, edc_juris])
    if s2.intersection(s4)
        return "YES"
    else:
        return "NO"
and call it like this:
TextValue(!JURIS!, !MGMT1!, !MGMT2!, !MGMT3!, !EDC_MGMT!, !EDC_JURIS!)
