Comparing Geodatabase Schema using python
3851
04-02-2013 11:36 PM
manleechowdhury
Can anybody help me with some suggestions as to how to compare schema of two geodatabases through python scripting? What would be the simplest way to approach for this comparison using python code?
ganeshnarim
Did u check here...http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00270000003w000000.htm
JakeSkinner
Esri Esteemed Contributor
Hi Manlee,
You can use the Feature Compare tool to compare feature classes.  There is an option to compare only the schemas.  You could script it so that you iterate through each feature class in each geodatabase.
