Clip converts my 16bit unsigned data to 32 bit - bug ?
3181
04-05-2011 11:28 PM
MichaelStjernholm
Hi
I'm processing a huge bunch of large images. A part of the operation is to use Clip_management to cut-out a part of the image using a vector feature. Unfortunately Clip always produce a 32-bit unsigned int despite the input is 16-bit unsigned int. I use tiff as output  format and have tried to set the compression to both "NONE" and LZ77" without any luck
How can I force 16-bit output without having to use the processing costly route of:
arcpy.CreateRasterDataset_management(path, filename,PixSiz,pixelType.get(str(ValueType),"16_BIT_UNSIGNED"),outputSR, nBands)
followed by
arcpy.Mosaic_management operation - which beside adding an extra processing step also become quite computing intensive as you can't prohibit pyramids building when having images larger than your screen size or similar !
The problem seems specifically related to the "Clipping with geometry", which I need to use as I :
a) neeed to reduce size to minimu
b) later need to calculate the histogram for a specific area using BuildRasterAttributeTable.
The help does include a warning "If Clipping Geometry is used, then the pixel depth of the output may be promoted. " - But it is not clear when and why the change happens
Is it in reality a bug seen by others ? I run win7 on 64-bit, Arc 10 SP1
All ideas are welcomed
Michael
MichaelStjernholm
i've now found that there most probably is an error in the Clip routine, which by the way also migrate into "Extract by mask" !
My data contained the value of 0 and had a NoData value assigned to 65536.
I could fortunately in this case consider my value of 0 as NoData, and thus circumvent the problem by using
    arcpy.Clip_management(inName,"#",outRaster,maskLYR,"0","ClippingGeometry")
rather than
    arcpy.Clip_management(inName,"#",outRaster,maskLYR,"","ClippingGeometry")
regards
Michael
MelanieSummers
Hi Michael,
Please take a look at this KB article:
FAQ:  Why does the data bit depth increase when a raster is projected, rotated, or clipped?
http://support.esri.com/en/knowledgebase/techarticles/detail/28470
If your raster contains values that range from 0 to 65535, ArcMap may assign the raster a NoData value of 65536 pushing the bit requirement up to 32.
If your data does not span the entire 0 to 65535 you can specify a no data value within the range allowing ArcMap to output a 16 bit raster.
Best,
Melanie
