Check that features have been selected
2475
05-24-2012 06:48 AM
BrianPangtay
Can one check if any features have been selected in a Python script?
I want to check if any features have been selected prior to running the script. Otherwise, the script would try to process all the records in a feature class. Thus, if no features are selected, the script would tell the user to select some features and then exit the script.
Thanks for your help, Brian
BruceNielsen
One method I've used in the past is to compare the number of features in the input layer (arcpy.GetCount_management) with the number in the layer's source data (arcpy.describe::CatalogPath). If they are the same, nothing has been selected.
NobbirAhmed
Esri Alum
Your selection is on a layer, right? if so then use FIDSet as follows:
dsc = arcpy.Describe("LayerName")
selection_set = dsc.FIDSet
if len(selection_set) == 0:
    # no feature is selected
JoseSanchez
How do you write this same code in 9.3.1?
NobbirAhmed
Esri Alum
I think it is the same for 9.3 as well. Follow this link - you will see FIDSet property on a described object for a layer:
http://webhelp.esri.com/arcgisdesktop/9.3/index.cfm?TopicName=Layer_properties
deleted-user-8KkqhMYcTNGx
I found that this worked for me:
layers = arcpy.mapping.ListLayers(mxd)
for layer in layers:
    desc = arcpy.Describe(layer)
    selcount = desc.fidSet
    if layer.name == "san_Wye":
        print layer.name
        if selcount <> "":
            print "{0} features selected".format(len(desc.fidSet.split(';')))
        if selcount == "":
            print "no features selected"
