Check for existence of a field
39507
9
08-03-2011 08:07 AM
MikeDriver
How do you check for the existence of a field in a feature class?  v10.
I did this, but it seems clunky.
import arcpy
fc = r"C:\temp\test.shp"
desc = arcpy.Describe(fc)
flds = desc.fields
fldin = 'no'
for fld in flds:
   if fld.name == 'USNG':
        fldin = 'yes'
print fldin
MikeDriver
Lines:
fldin = 'yes'
should be indented, of course.
JakeSkinner
Esri Esteemed Contributor
Your code will work with no problems.  You can also use the 'arcpy.ListFields' function.  Ex:
lstFields = arcpy.ListFields(fc)
x = False
for field in lstFields:
    if field.name == "USNG":
        print "Field exists"
        x = True
if x <> True:
    print "Field does not exist"
I tested the Describe function vs the ListFields function using the time module, and the ListFields function was slightly faster by a tenth of a second.
Also, to preserve indentation when copying/pasting your code, select your code and click the '#' button at the top.  It will wrap it in CODE tags.
StacyRendall1
if "USNG" in lstFields:
else:
Not sure if there is any speed difference... The 'in' thing is pretty handy for checking if something is in a list - in this case the ListFields is a list. For example:
>>> a = [3,5,6,'kitty']   # a Python list
>>> b = 2
>>> b in a
False
>>> c = 5
>>> c in a
True
>>> d = 'kitty'
>>> d in a
True
TylerCovington
This is the most direct. Your code is so clear and concise. Well done!
curtvprice
MVP Alum
Stacy's arcpy.ListFields returns a list of field objects (not field names) so the "in" operator would not work. You could make it work by converting the list to field names (and converting to upper case because the in operator is case sensitive).
field_names = [f.name.upper() for f in lstFields]
if "USNG" in field_names:
else:
    print "Field does not exist"‍‍‍‍‍‍
Brownschuh
Tested Stacy's code above and curtvprice is correct, the "in" operator will not work.
MikeDriver
Thanks all!
curtvprice
MVP Alum
An empty list evaluates to False so here's the way I do it:
if arcpy.ListFields(tbl, field_name):
else:
     print "Field doesn't exist"
It should be noted that AddField_management does not fail if you add a field that exists already, it just prints a warning and doesn't do anything. (Makes for less complicated ModelBuilder models.)
Brownschuh
This code worked for me.  Using a couple for loops I was able to run this against multiple feature classes within multiple feature datasets to determine if a field was present.
