I have gotten around this issue with other languages and other ODBC api's by:
Yes No field in Access is either -1, 0 no nulls. I have had success by passing a non null tiny int/small int to an access Yes/No field if it is already pre-exisiting.
For table creation with an access Yes/No field, I pass thru a DDL statement to access to create the table then populate it with non null -1,0 values as neccessary for Yes/No True/False.
The DDL field type to pass is "YESNO"
CREATE TABLE TestAllTypes
MyText TEXT(50),
MyMemo MEMO,
MyByte BYTE,
MyInteger INTEGER,
MyLong LONG,
MyAutoNumber COUNTER,
MySingle SINGLE,
MyDouble DOUBLE,
MyCurrency CURRENCY,
MyReplicaID GUID,
MyDateTime DATETIME,
MyYesNo YESNO,
MyOleObject LONGBINARY,
MyBinary BINARY(50)
I would imagine that a DDL "Alter Table" would work in a similiar manner. I believe PyODBC requires you to commit when you pass the DDL SQL...
import pyodbc
con = pyodbc.connect(r'DRIVER={Microsoft Access Driver (*.mdb, *.accdb)};DBQ=Z:\Data\Instruments\testDB.accdb; Provider=MSDASQL;'cur = con.cursor()
string = "CREATE TABLE TestTable(symbol Text(15), leverage double, shares YESNO, price double)"
cur.execute(string)
con.commit()
