CAST does not work in SearchCursor Queries?
4096
11
07-17-2018 02:39 PM
DougBrowning
MVP Esteemed Contributor
I thought a found a slick way to compare on a number in a string field.
CAST(SoilDepthLower AS INTEGER) < 70
This works in a ArcMap definition query just fine.
But when I try to use it in a SearchCursor Query it says Invalid SQL Statement.
                    whereClause = "CAST(SoilDepthLower AS INTEGER) < 70"
                    keyField1 = arcpy.ListFields(tableLayer)[1].name
                    keyField2 = arcpy.ListFields(tableLayer)[2].name
                    fieldList = ["SoilDepthLower", keyField1, keyField2]
                    with arcpy.da.SearchCursor(tableLayer, fieldList, whereClause) as cursor:
I have tried smallint, double, etc - using both uppercase and lower case.
This help page says it is supported  http://pro.arcgis.com/en/pro-app/help/mapping/navigation/sql-reference-for-elements-used-in-query-ex...
What is the issue?
DougBrowning
It is a python in_memory table (not a FC) which in my experience acts just like a GDB.  When I make a test copy into a GDB and use my cast query in a Definition Query it works great.  Which should simulate the interface directly.
I have tried int, INT, Interger, INTEGER, SHORTINT, and a few others.
thanks
JoshuaBixby
If you feel one of these responses answered your question, please mark it so to close out the question.  Otherwise, I will close it as "assumed answered" later.
